Behold the one piece window!
Old Feb 22, 2014 | 08:02 PM
  #31
DCrusher's Avatar
DCrusher
Originally Posted by hivoltj
How do you install the window in the channel? Put it in diagonal and straighten once it's in there?
Yap on a VW one piece you tilt it and slide it in and then straighten into the channels roll up the window then set it into the regulator.
Old Feb 23, 2014 | 04:19 AM
  #32
jowilker's Avatar
jowilker
May I offer a suggestion? Look at the newer trucks today, they all have a triangle piece that fits in the leading edge of the door with a mirror on it. Can one work a triangle filler down there, replace the vent window, take care of the hinge, AND have something there that is useable for backing the darn truck?
That is something that has been kicking around in my dust bin for a while.
John
Old Feb 23, 2014 | 08:34 AM
  #33
f100today's Avatar
f100today
John
Kinda like the guy with the 66 did in the link on post #21?
Old Feb 23, 2014 | 11:58 AM
  #34
yellow truck's Avatar
yellow truck
Where will you flick your cigar ash?
Old Feb 23, 2014 | 04:29 PM
  #35
jowilker's Avatar
jowilker
To be honest, I am thinking the complete vent window area. If I may, should one use this whole area, one could install a modern mirror, that our trucks need very badly, and you don't have to reinvent the wheel.
There have been hours upon hours devoted to this very issue of a one piece window, and there still isn't an easy answer. It is a noble challenge indeed, but this could be an alternative.
Ford started using this around 2000, a much different slant but my 06 has a good example.
Just a thought.
John
Old Mar 1, 2014 | 03:28 PM
  #36
Aesop's Avatar
Aesop
Bump.
Get to work.
Old Mar 1, 2014 | 03:51 PM
  #37
f100today's Avatar
f100today
Originally Posted by Aesop
Bump.
Get to work.
Sorry guys. Unfortunately it is going to be a slow affair for the next couple of months. My boys started baseball and my side business has exploded. That is what pays for my sickness ha ha. So it may be a while. I did go buy another short bed today. Found one cheap that had a good bed on it. The inside of the bed was trash, but the sides were dang near perfect. I had to fab the inside of the bed anyway, so it really didn't matter.
Maybe someone can get it done before me!
Old Mar 1, 2014 | 06:11 PM
  #38
gangstakr's Avatar
gangstakr
Just a thought.
John
Hey John, I've heard a few people complain about the outside mirroes on the "Slicks", but for the life of me I can't understand why. My mirrors are original, perfectly adjusted for me and I've never had an issue. I see clearly, my vent windows don't get in the way.
On my 69 I had the small door mounted mirrors with no problems either.
What kind of problems do you have?
Does anyone else have problems with the original style mirrors?
Old Mar 2, 2014 | 12:12 AM
  #39
orich's Avatar
orich
Me those Min west coast mirrors dang blind spots at 4way stops a few time. Almost got a biker & VW just a few I remember since 1978-2005 when, I removed them..
orich
Old Mar 2, 2014 | 11:32 AM
  #40
dsrtjeeper's Avatar
dsrtjeeper
orich
Me too. These mini mirrors are worthless in Phoenix traffic. Blind spots on both sides and I have to turn my head and look before merging. These days if you turn your head for a split second; some idiot cuts in front of you or nails their brakes. I however like the looks of these mirrors.
Old Mar 2, 2014 | 12:06 PM
  #41
orich's Avatar
orich
Oh and let me add another reason why, I don't like them. I don't remember how many times
but at least 1/2 a dozen when coming out from under my truck and hit my head or forehead that broke the skin and left some type of battle scares.
This was my main reason for removing them as, I don't heal as fast as.
I once did when younger. Then my doc at the VA said, I should be taking an 81mg baby Aspirin to help keep my blood thinned. Yeah right, the down side is you bleed longer then normal when you break the skin. Plus having type ll diabetes. And being older you end up with damn bruises all over your arms & hands when you bump yourself very light against something hard.
orich ..TO THESE
Old Mar 2, 2014 | 12:11 PM
  #42
dsrtjeeper's Avatar
dsrtjeeper
orich
The larger mirrors would be easier to hit with your head! LOL! Don't ask how I know.
Old Mar 2, 2014 | 12:15 PM
  #43
dsrtjeeper's Avatar
dsrtjeeper
P.S. Seating position will effect how one views their mirrors also.
Old Mar 2, 2014 | 12:36 PM
  #44
f100today's Avatar
f100today
I found that with my last f100 I had as a daily driver I actually never used the mirrors. I just turned my head and was probably more aware of my surroundings. I am 99% sure I am going to not have any mirrors on my current build.
Old Mar 2, 2014 | 07:16 PM
  #45
orich's Avatar
orich
Don't come to cailf as you'll get nailed by the CHP must have at least one.
If your not towing & if towing must have have L & R outside mirrors and be able to see 300ft.behind you from each mirror ..
orich
