Zf6 clutch issues
Old Feb 17, 2014 | 04:33 PM
Billy Follert's Avatar
Billy Follert
Zf6 clutch issues
I recently did a cab swap on my 99 psd, the cab was from an automatic and my truck has a 6 speed, after swapping everything over and hooking all the lines up i pushed the clutch in and it went right to the floor, it doesnt feel like there anything behind it just a pedal floating there, any ideas on whats causing this or how to fix it? i put the reservoir on and filled it up to the top and held it as high as it would go to try to get the air out of it but evidently it didnt work
Old Feb 17, 2014 | 05:13 PM
jetdoc's Avatar
jetdoc
Did you use a pre bled unit? I've never had much luck after breaking the system open. What kind of clutch did you use?
Old Feb 17, 2014 | 05:16 PM
Billy Follert
everything is stock all i did was diconnect the high pressure plastic line going from the clutch pedal down into the transmission
Old Feb 17, 2014 | 06:36 PM
F350-6's Avatar
F350-6
I've never looked. Does the cab for the auto have a punch out plate you can stick the clutch master in?
How did you bleed the clutch hydraulics? The only success I've had trying to bleed them is to remove the clutch master from the firewall and let it hang so it's pointing down hill. Remove the slave cylinder from the bell housing, then remove the cap on the reservoir. Slowly pump the rod on the slave cylinder about 100 times (that's what felt like it took me) until you don't see any more bubbles coming up in the reservoir.
Old Feb 17, 2014 | 07:20 PM
Billy Follert
yea everything is hooked up like it should be the cabs are set up for standard all except for the floor pan, but i dont want to unbolt the transmission from the engine to bleed it, i never bled it to start with but i figured that i didnt push any air into it because the slave and lines were all full
Old Feb 17, 2014 | 07:27 PM
F350-6's Avatar
F350-6
You don't have to touch the transmission. The slave cylinder comes out of the bell housing with a 1/4 turn counter clockwise. Then just pull it out slowly. There's a plastic tip on the end of the slave rod that has wings that can hang up and cause the tip to fall off in the bell housing if you're not paying attention.
You might need a pair of channel locks to turn the slave cylinder, but it comes out of the bell housing quicker than you can get the plastic line off of it.
Old Feb 17, 2014 | 08:05 PM
Billy Follert
sweet so all i need to do is unbolt the clutch pedal so the line is higher than the master?
Old Feb 17, 2014 | 08:12 PM
F350-6's Avatar
F350-6
No, remove the rod going to the hydraulics from the clutch pedal. There's a plastic bushing in there. Stick a small flat screwdriver between the bushing and the rod sticking off the side of the clutch pedal and pull out. The bushing and rod should come off the pedal. Then remove the master from the firewall by giving it the same 1/4 turn and pull it into the engine bay. From there, point the master down hill and then do the bleed procedure.
Old Feb 17, 2014 | 09:00 PM
Billy Follert
great man, thanks alot, ill give it a try tomorrow or the next day
jle70
1978 - 1996 Big Bronco
Dec 24, 2013 09:47 PM
chrisginco
Sep 3, 2012 07:53 PM
bigcrunch
Mar 6, 2010 12:15 PM
Kymber
Mar 20, 2007 07:17 PM
DT 466Man
Jun 27, 2005 07:57 AM
