Electrical problems!!
Old Feb 16, 2014 | 04:41 PM
Ahamp89's Avatar
Ahamp89
1996 f250 powerstroke. Radio is on even with key off its lit up and no longer works at all. voltage gauge swings,dash lights pulse with gauge swing, truck Is starting to idle erratically please help
Old Feb 16, 2014 | 05:00 PM
ReBilld's Avatar
ReBilld
I would start by unplugging the radio and see if the dash lights and volt gauge clear up.
Old Feb 16, 2014 | 05:02 PM
Ahamp89's Avatar
Ahamp89
Ok I'll do that. I pulled fuses with the key off and the radio was still lit up...
Old Feb 16, 2014 | 05:09 PM
ReBilld's Avatar
ReBilld
Which fuses did you pull?
Ahamp89's Avatar
Ahamp89
Old Feb 16, 2014 | 05:10 PM
Ahamp89's Avatar
Ahamp89
Radio memory and I think there was another radio fuse
Old Feb 16, 2014 | 05:29 PM
ReBilld's Avatar
ReBilld
Maybe try pulling every fuse in the box one at a time and see if the radio goes off. That will give you an idea to what circuit to start looking at for a short. Also, you might pull the headlight switch out and make sure the back of the switch and plug are not burnt or melted. That's a common problem and good place for wires to get melted together.
Old Feb 16, 2014 | 05:51 PM
madpogue's Avatar
madpogue
Aftermarket or stock radio?
Old Feb 17, 2014 | 11:26 AM
Ahamp89's Avatar
Ahamp89
Aftermarket
Old Feb 17, 2014 | 11:51 AM
madpogue's Avatar
madpogue
Decommission the radio itself, then test again. If everything works normally, reinstall the above fuses and test yet again. If all is still normal, radio is miswired.
Is there a "crossover" harness between the factory radio connector and the aftermarket radio, or was the factory connector cut?
Old Feb 17, 2014 | 12:34 PM
Ahamp89's Avatar
Ahamp89
It's wired right and it's been in there for years and never had a problem
Old Feb 21, 2014 | 11:17 AM
Ahamp89's Avatar
Ahamp89
New voltage regulator took care of all the problems
Old Feb 21, 2014 | 11:54 AM
madpogue's Avatar
madpogue
WOW, that's a new one. Can you share with us HOW you figured that out?
Old Feb 21, 2014 | 11:57 AM
Ahamp89's Avatar
Ahamp89
My brother had the same problem in an older truck figured I'd give it a try and everything is back to normal
Old Feb 21, 2014 | 03:26 PM
ReBilld's Avatar
ReBilld
Good deal! Glad you figured it out. Thanks for sharing it with us!
Danielsm17
Dec 30, 2018 06:00 PM
Jterr
Aug 5, 2017 06:34 PM
azplumber
Jan 2, 2016 09:36 AM
whalebus2112
Jun 26, 2013 06:15 AM
chaseface84
Apr 30, 2004 02:04 PM
