Clutch cable broken
Old Feb 15, 2014 | 10:34 AM
barely alive's Avatar
barely alive
Clutch cable broken
We just had the deepest snow we have had in more than 10 years. I decided to pull my Bobcat to do some clearing and got thru the first day when my son said the truck would not drive and smelled like clutch burning. I found the clutch pedal had no pressure until almost at floor. I think cable broke or possible slave cylinder? This is a 1984 f-250 with 6.9. It is on side of road now with snow pushed around it. Clear and cold today so I guess I will see what is wrong. Ever replaced this cable anyone? I sheared the pin that clutch pedal pivots on a few years ago. Lot of pressure on this.
Old Feb 15, 2014 | 10:37 AM
Chevy_Eater's Avatar
Chevy_Eater
It's hydraulic, so no cable.
Old Feb 15, 2014 | 10:47 AM
bashby's Avatar
bashby
A hydralic failure will not cause clutch slippage, but will not let it disengage when you push the pedal in. Sounds to me like the clutch itself is shot. Remove the inspection plate and take a look.
Old Feb 15, 2014 | 02:09 PM
barely alive
Ok, just looked and there is no cable just a pushrod that goes thru firewall to the slave cylinder. I just looked and saw rod moving when pedal moves. There is no resistance with pedal travel other than compression spring on linkage where the pedal pivot is. I see no fluid movement at slave cylinder.
My son said pedal traveled half way to floor before any engagement pressure was felt for a few shifts, then no pressure and could not get shift lever to move or shift to neutral when it got stuck.
Where is inspection plate? Visible from under vehicle at bell housing? Guess I need to get truck out of snow and to dry place to climb under and see.
Old Feb 15, 2014 | 03:37 PM
barely alive
Hydraulic clutch
I guess I do not know enough to diagnose this. The correct parts and their names are eluding me. I guess I have been working on old motorcycles too long. The actuator arm from pedal thru firewall has an adjustment screw on the pedal side of firewall. I guess this arm or pushrod goes directly into a master cylinder on engine side of firewall. I do not see any fluid movement in the reservoir when clutch pedal is pushed. The slave cylinder is at other end of hydraulic line where it actuates clutch. Is there any part diagrams or repair manuals showing this system? Are my part names and description correct?
Old Feb 15, 2014 | 03:59 PM
bashby's Avatar
bashby
Your terms are correct, pushrOd attaches to the master which sends fluid down to the slave. The burning smell is what makes me think your clutch is shot. If the clutch is good and hydrLics failed, it should try to take off if you start it in gear with the clutch depressed and in gear. If you start it in neutral you won't be able to get it in gear. What,s it doing?
Inspection plate is underneath. You won't be able to tell much unless the clutch is really bad.
Old Feb 15, 2014 | 04:31 PM
barely alive
No clutch pressure at pedal. Can not shift gears easily. My son told me he was in 3rd when he stopped and pushed clutch in, motor stalled, and could not shift again. When I got there he said they tried starting in 3rd gear and that is when they smelled burning clutch.
Don't think starting in granny gear to see if clutch disengages is helpful since gear shift will not move in or out of gear easily.
Old Feb 15, 2014 | 04:35 PM
barely alive
This is a 4wd. Is it ok to pull it to place I can work on it? It was in 4wd with hubs locked when it stopped.
Old Feb 15, 2014 | 11:39 PM
Sycostang67's Avatar
Sycostang67
Just unlock the hubs and put the transfer case in neutral before you pull it. The firewall where the clutch master cylinder mounts is a weak point on these trucks as well. Have someone push on the clutch pedal while you watch the clutch master and see how much it moves. I got a truck real cheap because the fella thought the clutch was gone and it was just a torn firewall.
Old Feb 16, 2014 | 12:51 PM
barely alive
Thanks, I will look at this.
Old Feb 16, 2014 | 04:12 PM
barely alive
Since the pedal has no pressure I don't think movement of the firewall will happen. Wouldn't pressure plate cause the hydraulic pressure to move the pedal back up. I guess if slave cylinder went bad it could be stuck in depressed condition not allowing fluid to move the master cylinder and pushrod back to pedal. I just thought fluid level in master cylinder would be low in this case.
68shortbedmo
Dec 31, 2015 10:52 AM
MFogarty1996
20
Apr 22, 2011 04:53 PM
customstringer
1983 - 2012 Ranger & B-Series
Nov 29, 2006 07:39 PM
smuggler
13
Jun 27, 2005 09:23 PM
AKsteel
Jun 15, 2004 04:21 PM
