Clutch Cable? Help Asap
Old Jun 15, 2004 | 10:28 AM
AKsteel's Avatar
AKsteel
i have a 93 f150 2wd and while i was driving i went to change gears and when i pushed down on the clutch i heard a loud pop/snap and the clutch has no pressure. i can pull the pedal up and down...is it just a cable or could it be something else. if it is just a cable is that cheap and is it hard to replace thanks. need help asap
Old Jun 15, 2004 | 04:21 PM
EPNCSU2006's Avatar
EPNCSU2006
The clutch on these trucks is hydraulic. I've heard that the master cylinder pushrods are made of plastic on some of the newer models, so maybe that is what snapped. Look up under the dash and see if you can find anything obviously wrong. Move the pedal and watch to see where the movement stops.
