No Instrument Lights
Old Feb 14, 2014 | 10:09 PM
AirMakesMeCrazy's Avatar
AirMakesMeCrazy
'89 F350 Custom
I have head lights, hi and low beams, interior dome light, exterior cab light, running lights, all the idiot lights and radio. But I don't have any instrument lights. I started to take my instrument cluster apart, but it seems like it's going to be hard to remove with the speedo cable and such.
Any thoughts on taking the gauge cluster out to replace the light bulb(s), or have a suggestion to help me trouble shoot the lights?
Old Feb 14, 2014 | 11:14 PM
88n94's Avatar
88n94
I wouldn't think all the instrument light bulbs would burn out at once. I would guess more in the light switch. Do the lights by the heater controls light up? Have you tried turning the **** on the light switch back and forth?
Old Feb 14, 2014 | 11:26 PM
PRIMERED79 SHORT BED's Avatar
I have a 92 f150 custom and my headlight switch will act up and i will have to turn it till the lights turn on, but if i move it past that point they shut off.
Might try turning your headlight **** slowly to see if they turn on at a certain point.
Old Feb 15, 2014 | 12:46 AM
HD's Avatar
HD
i wouldn't start at the cluster. Here is a 1991 f-150 schematic. I know it's not an 89, but it's probably similar I would think.
https://www.ford-trucks.com/forums/p...ctureid=149511
If nothing else (ash tray light, a/c lights, wiper switch light, etc) is working either it might be a bad fuse. The radio has two lighting circuits, one after the first fuse and one after the second fuse, so the radio light doesn't mean all fuses are good. If all fuses are good, then I would look at the light switch. A wire may have come out or something.
Yours may be a little different, but hopefully this gives you a good starting point.
Old Feb 15, 2014 | 04:27 AM
wr310rdr's Avatar
wr310rdr
had this same issue with my '92, it was a bad switch, 15 bucks and it was fixed
Old Feb 15, 2014 | 05:29 AM
AirMakesMeCrazy
Thanks guys. I'll take a better look at that switch after work, and leave the instrument cluster alone for a while.
Old Feb 15, 2014 | 08:48 PM
AirMakesMeCrazy
Got it… Thanks for all the help guys.
It ended up being a fuse that was missing completely. I thought the space was just a blank, but it ended up being the space that brought the cluster to life. And is surely wasn't the space that was indicated on the fuse diagram. Crazy.
zombiesawyer
Aug 21, 2023 10:50 AM
natedog37
Aug 18, 2020 01:06 AM
ScottyC50
Aug 23, 2018 08:18 PM
80ford100
16
Nov 16, 2014 05:01 PM
03_PSD
Oct 10, 2009 03:21 PM
