Tricks for removing receiver hitch
Old Feb 14, 2014 | 02:17 PM
sandfarmer's Avatar
sandfarmer
Disregard this post, the hitch doesn't have to come off...
Old Feb 14, 2014 | 08:09 PM
Fellenz's Avatar
Fellenz
I know it says disregard but I got mine out today after it being stuck for months!
I hooked it to a tractor and went ***** to the wall, finally people out after a couple yanks.
Disclaimer: Not reccomended! And will likely get you a scolding here on the forum for doing a "hold my beer" action
Old Feb 15, 2014 | 08:03 PM
bwbarnes's Avatar
bwbarnes
I'm going to be replacing my rusty hitch soon on my 2001 Excursion. So I would appreciate tips from anyone who has been there and done that.
Old Feb 16, 2014 | 04:45 PM
saz2686's Avatar
saz2686
On an old truck, Failed attempts
Tried to beat it out with a mini sledge hammer.
Tried a come along to a big tree.
Tried cussing it out.
I gave it a P.B blaster bath and a hammer waited a few days and one more bath and hammer. After a week I chained it to a BIG tree and gave it a few good bumps before it finally came out.
Old Feb 16, 2014 | 08:30 PM
bwbarnes's Avatar
bwbarnes
I'm going to be replacing the entire hitch that is bolted to the frame. I've got a good used one. I'm hoping to swap it out without dropping the gas tank. I've been looking under the Excursion planning my attack. It looks like I will have little trouble unbolting the old hitch but accessing the nut plates with the tank in place will be a trick. I would like to hear from those who have done the swap and have learned the best approach.
Old Feb 16, 2014 | 09:08 PM
7.3Excursion4x4's Avatar
7.3Excursion4x4
HEAT HEAT HEAT. Heat up the tube with MAP or Acetylene gas if you have it available. Get the receiver nice and hot all the way around and spray a penetrating oil around the hitch and the heat will draw the oil in. Tap on it with a hammer and pull it out. I do this all the time on salt water soaked units that have been stuck for years. Just be patient.
You can get MAP gas at any hardware store. It is in the yellow bottle and is 3 X hotter than the blue propane tanks.
Old Feb 16, 2014 | 11:45 PM
Topgear24's Avatar
Topgear24
Get a can of WD-40 a mini sledgehammer grab your chain and tie it up to something big and gun and hope for a clean break. Repeat in tell it come off or you break something.
Old Feb 17, 2014 | 12:25 PM
RMBC Freeride's Avatar
RMBC Freeride
Some good info was covered here:
https://www.ford-trucks.com/forums/1...ml#post9933469
EpicCowlick
Jan 19, 2017 08:23 PM
nullop
Jan 13, 2017 12:25 PM
RA31925
All Things Towing
Mar 13, 2013 04:51 PM
rambuck
13
Feb 13, 2009 10:32 AM
luxury 4x4
All Things Towing
Jul 19, 2001 09:18 PM
