68 disc conversion
Old Feb 14, 2014 | 10:20 AM
Uni Moe's Avatar
Uni Moe
68 disc conversion
So I've saved a couple of tech articles on disc brake conversion. Am I correct that you can replace the whole I-beams from a 73-79 donor OR you can use your current I-beams and just use the spindles from the donor vehicle? Any advantage or disadvantage to either method?
Old Feb 14, 2014 | 11:20 AM
money pit 69's Avatar
money pit 69
Hi Unimoe, This is money pit 69 I had the same question. There was lots of useful response info. to my tread. Look on page 2 for my post about disk brakes and you will get your answer. Hope that helps. THX David
Old Feb 14, 2014 | 03:30 PM
RichS2659's Avatar
RichS2659
Think of it this way: it is much easier to basically drop 2 bolts and a hose and get the whole I-beam than to have to play with the kingpins if you take just the spindles.
Old Feb 14, 2014 | 06:15 PM
jowilker's Avatar
jowilker
I dropped the complete I-Beam set from a 76, slid it over and bolted it up under my 66. Everything is bolthole exchange. I included power steering with the disc brake swap. While it is not easy it is simple.
John
Old Feb 14, 2014 | 06:34 PM
Ford_Six's Avatar
Ford_Six
Power Steering & Disk Brakes 2wd 65-72 .: Articles
Here's what I did.
thrash911
Sep 3, 2015 10:59 AM
Pondbird
May 14, 2014 05:35 PM
jtwhite
Sep 22, 2010 03:41 PM
BorisPalance
Apr 14, 2009 11:02 PM
Kieran_L
Apr 18, 2007 06:54 AM
