More Disc Brake Conversion Questions
Old Apr 7, 2009 | 02:33 PM
BorisPalance's Avatar
BorisPalance
Hello all,
This is my second post. On the first post, I realized that I didn't say hello and thanks for the great forum. Very good information here and a lot of knowledge to be passed on.
That being said, on to my issue. I'm stuck sourcing parts for the disk brake conversion on my '66 F-100. I'm having a difficult time finding a good donor in my area. The article by Dennis Austin (link below) on the Drum to Disc conversion suggests using '74 F-100/F-150-250 spindles for converting the '65-'66 F-100s.
https://www.ford-trucks.com/article/...cks.html#item1
Does anyone know why only that year was suggested and what the differences are? Can't I use any '73-'79 spindles?
Thanks for reading through this, and any advise is appreciated.
Old Apr 7, 2009 | 03:27 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
BorisPalance
Heres an artiicle that Ford_6 wrote this it is about pulling I beams and all together
Hope this helps also?
Link>>>
https://www.ford-trucks.com/article/..._2wd_6572.html
Old Apr 8, 2009 | 05:44 AM
ddavidv's Avatar
ddavidv
Anything up to '79 works, though there is some debate on kingpin size over the years, but if you pull the entire I-beams that doesn't become a problem. My how-to, in case you haven't found it yet:
f100discs
Old Apr 8, 2009 | 05:59 AM
jowilker's Avatar
jowilker
I agree with Dwight, but recommend buying your donor to harvest your parts from. I suggest the disc brake and power steering swap be done at the same time. If you have a FE engine you will have to limit your search to 76 as that was the last year they were installed.
Find a donor with a running gear that you want your truck to end up with and go from there. Sometime stopping at someones house with one parked out back can be a source.
John
Old Apr 10, 2009 | 09:04 PM
kustom 65 short box's Avatar
kustom 65 short box
I have what you need. I will be selling Disc brakes complete soon. They will bolt on to your stock I beams. It will come with new spindles. Call 262-352-4883 for more info
Old Apr 11, 2009 | 05:39 AM
jowilker's Avatar
jowilker
Will you be offering everything for the completion, including master cylinder, booster, porp. valve, new lines, newly required line hangers and any other parts?
John
Old Apr 11, 2009 | 10:42 AM
kustom 65 short box
I will have everything from the I beams to the brakes. I will not be selling the power brake booster.I am doing a sub frame swap but I will still need that.Every thing form the fire wall forward will be available.
Old Apr 11, 2009 | 04:53 PM
jowilker's Avatar
jowilker
Then I beg to differ you will not have everything he will need, as he will need those parts as well.
John
Old Apr 12, 2009 | 11:53 PM
kustom 65 short box
Maybe so, but the easy part is finding the master cylinder and pro valve. It is a great kit and it only has 5k on it. Almost brand new for half the price. Seems like a no brainer.
Old Apr 14, 2009 | 06:02 PM
65fordguy's Avatar
65fordguy
I pulled the entire front set up- power brakes, power steering, and disc brake setup out of a 75 I beams, spindles, rotors, Master Cyl- booster, pumps, pulleys, tierods, ehh you get the picture.. 100 bucks I believe I payed for it... couple hundred to rebuild and replace.. and my truck drives like a town car... kinda.
Old Apr 14, 2009 | 11:02 PM
BorisPalance
Thanks for all the input fellas. I ended-up finding complete disc spindles, Pvalve, master cylinder and booster from a '78.
Since I'm installing lowered beams on my '66, I didn't take the I beams from the donor. Made a quick call to DJM and they varified that the King Pins in their kit will work fine with the newer '78 units.
