General Automotive Discussion
Fast Trucks?
Old Feb 14, 2014 | 07:07 AM
madmacs's Avatar
madmacs
Fast Trucks?
First, if you are going to build a truck for racing, why would you not start with the lightest weight chassis you can get? Most of these talked about are loaded up king ranch crew cab trucks, why push that extra thousand pounds around? These kind of trucks are why a strippie cost 25k. Some one has to subsidise those people haulers. If a 5k# truck will run 12's, a 4k# hopped up the same way should run low to mid 10's. Now ya got a real truck. Same thing with that diesel at Bonneville, those crew cabs are not light, take all of that weight out and watch it go...
Old Feb 17, 2014 | 10:32 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
It totally depends on what type of racing you would do....
Old Feb 17, 2014 | 08:14 PM
madmacs's Avatar
madmacs
Racing to the bottom of a lake maybe..
Old Feb 17, 2014 | 09:04 PM
IB Tim's Avatar
IB Tim
OK 1K of concrete
Old Feb 17, 2014 | 09:06 PM
merc2dogs's Avatar
merc2dogs
My 'normal' go fast mods with cars/trucks is to strip them out.
I've pulled stock carpet out of cars that had enough dirt and crud embedded that I needed help to throw it in a dumpster.
My old mustang weighed 3200 lbs when I bought it, after stripping it, swapping engine/transmission and installing a 6 point cage, it tipped the scales at 2880.
Other mustangs of the same year,with the same general build that had the original interiors simply couldn't touch it on the strip or street. (but then I also modified the firewall so I could move the engine back 6 inches for better weight balance....)
So yes, lightweight is the way to go!
The old saying is that losing 100lbs is the same as adding 10 horses, don't know how accurate that ratio is, but less weight does require less horsepower to get moving.
Old Feb 18, 2014 | 02:29 AM
Furyus1's Avatar
Furyus1
Just get a bull mastiff and and leave it alone in the car while you go shopping for a couple of hours... Come back; kick the dog out; shovel out the carnage; problem solved...
Old Feb 18, 2014 | 07:50 AM
madmacs's Avatar
madmacs
And that has WHAT to do with the TOPIC?
Old Feb 22, 2014 | 09:58 PM
BajaRacer41's Avatar
BajaRacer41
2014 Ram 1500 5.7 hemi, single cab. Very fast truck, 400hp stock.
Old Feb 22, 2014 | 10:02 PM
2ndStroke's Avatar
2ndStroke
I remove my tailgate when I wanna go fast, that's what 150 pounds?
Whooweeee!
swanee
2009 - 2014 F150
17
Nov 4, 2014 05:22 PM
Chief-e9
Jan 8, 2011 04:48 PM
factory594x4
Large Truck
Jun 1, 2010 11:42 PM
TwinTurboDiesel
May 3, 2007 10:24 AM
SCOTT_KODIAK
Feb 25, 2005 10:51 PM
