Power Steering Pulley Tool
Old Feb 13, 2014 | 07:08 PM
blageurt's Avatar
blageurt
Trying to replace a leaking hose ...I snapped off the plastic spout on the bottom of the resevoir...I would hope someome can send me a Link to which tool I need to Buy to remove the pulley and install it..... as now I have to replace the pump......I have some pullers but probably NOT the one I need ...Thanks In advance....
Old Feb 13, 2014 | 07:52 PM
pjwoolw's Avatar
pjwoolw
The K-D 2897 is what I have.
Old Feb 13, 2014 | 07:56 PM
madpogue's Avatar
madpogue
Cheap Harbor Freight version - Pulley Remover and Installer Set - or borrow one from the FLAPS.
Old Feb 13, 2014 | 10:01 PM
blageurt's Avatar
blageurt
Thanks alot Guys ..I really appreciate it as i need to fix it ASAP and it is only getting colder....back to the - teens next week ...I abstain from buying cheap tools ....so KD 2897 it is ....Are these sets similar ? http://www.summitracing.com/int/part...830a/overview/ or http://www.summitracing.com/int/part...4530/overview/
and what is FLAPS ?
Thanks alot for the help...
Old Feb 13, 2014 | 10:04 PM
madpogue's Avatar
madpogue
Friendly Local Auto Parts Store. Advance, AutoZtoned, etc. They "lend" out tools like pullers, spring compressors, etc. You put down a deposit or leave your CC#, but in the end it's free.
For what it's worth, the HF tool worked like a charm on my vac pump. I figure if I get 4-5 uses out of it among all the trucks, it'll pay for itself.
Old Feb 13, 2014 | 10:09 PM
blageurt's Avatar
blageurt
OK well here they lend out Garbage hoping you break it and have to pay for it...I would rather Buy it...thanks again...what about the OTC tools I listed ? which one is ok ?
Old Feb 14, 2014 | 09:02 AM
farmert's Avatar
farmert
If you have a NAPA stor near by
NAPA AUTO PARTS
I believe the OTC tools are what Ford issues as Rotunda tools used at the dealerships.
Old Feb 14, 2014 | 03:36 PM
blageurt's Avatar
blageurt
Ok guys..I bought the tool today @ Canadian Tire... looks small compared to what I thought it would be but I was assured it is similar to the KD / OTC tool in a fancy little case...it was 56 bucks with taxes and Lifetime warranty...Now I have to figure out how to use it and go from there....thanks alot
Old Feb 16, 2014 | 03:40 PM
Talyn's Avatar
Talyn
I bought a puller, then converted it to a pusher. just used a **** load of washers.
Old Feb 19, 2014 | 06:59 PM
blageurt's Avatar
blageurt
Thank God for a couple days of above freezing temps......
Aside form that , I finally got the beatch back together .....as of 5 Minutes ago ...No leaks......not bad for a pump that was in hibernation....for 15 years.....the most difficult part was optimizing the Tool....NO ROOM in a Van with the PSD..
Thanks to everyone for thier Input.....
brbuchanan
May 26, 2016 02:49 PM
cabloom300
Mar 11, 2011 01:24 PM
pipman76
Jul 9, 2008 09:32 PM
woody1003
17
Dec 8, 2007 06:32 PM
lumax
1983 - 2012 Ranger & B-Series
Nov 29, 2004 07:27 PM
