02 To 07 Explorer Transmission
Old 02-13-2014, 03:49 PM
weross67's Avatar
weross67
weross67 is offline
Arrow 02 To 07 Explorer Transmission
These trucks come with the 5R55S Or The 5R55W transmission can anyone tell me the difference or why there is Two numbers. Is one better than the other? I am also aware of the E & N series which are different but not used after 01.
Old 02-13-2014, 10:28 PM
jk080's Avatar
jk080
jk080 is offline
Transmission Rebuilder
There is a gear ratio change between the two, there are two ratios for the overdrive section. 5R55S is the Short ratio and the 5R55W is the Wide ratio. I dont think one is stronger than the other, they both brake bands, wear the servo bores, and have converter issues. They cannot be interchanged the computer would not like it.
5R55S --------- 5R55W
1st - 3.22 ------ 1st - 3.22
2nd - 2.29 ------ 2nd - 2.41
3rd - 1.55 ------ 3rd - 1.55
4th - 1.00 ------ 4th - 1.00
5th - 0.71 ------ 5th - 0.75
Rev - 3.07 ------ Rev - 3.07
The 5R55N is a lot alike the S/W, it has a couple of extra parts and different ratios as well. I am not sure what the "N" stands for on those.
The 5R55E is similar but completely different, no interchangeability of its parts.
Old 02-14-2014, 09:55 PM
weross67's Avatar
weross67
weross67 is offline
Thumbs up A Big Thanks
Thank you very much for your information that is very helpful.
Old 02-18-2014, 03:45 AM
Bierisch's Avatar
Bierisch
Bierisch is offline
So, do the 4.0s have the same transmissions? Or are they completely different?
Old 02-21-2014, 01:13 PM
weross67's Avatar
weross67
weross67 is offline
There is a code on the driver door post or door that you can look up on the net which should tell you if it is a E, S, Or W.
Rancheroracer
2009 - 2014 F150
03-15-2011 06:38 PM
Junkman of Delaware
02-25-2009 06:32 PM
bigblack02
1999 to 2016 Super Duty
10-20-2005 12:14 AM
talldog07
07-11-2002 11:04 PM
Quick Reply: 02 To 07 Explorer Transmission
