Sensor Wire questions
Old Feb 13, 2014 | 09:53 AM
svp_evo's Avatar
svp_evo
So I have my service manual and it references the wire part number on the harness and not the color.
1990 F250 351w
Would anyone be able to tell me what color the wire for the manifold water temp sensor is (the single wire booted plug that goes directly into the manifold, not the heater water neck) or maybe the single wire oil temp sensor at the lower portion of the front of the block.
If you can help I appreciate. My harnesses is stripped and they will both fit with plenty of slack. I can ring out the wires form the main ecu after I find the pinout for it, but this would make things easier.
Old Feb 13, 2014 | 06:18 PM
timbersteel's Avatar
timbersteel
On my '92, 302, water temp sensor wire color is Red/White-stripe.
Oil sensor wire is White/Red-stripe.
Old Feb 13, 2014 | 10:47 PM
svp_evo's Avatar
svp_evo
Thanks Timber.. i will double check mine. For some reason I think one was brown with a white strip =/
Old Feb 13, 2014 | 10:58 PM
timbersteel
I double checked my 1996 Haynes manual. It shows the same for both '90 and '92.
Mine's a bit brown at the connector, but red an inch or so up the line.
Hope that helps.
Old Feb 15, 2014 | 01:09 PM
svp_evo's Avatar
svp_evo
Thank you Sir. You are correct. I am looking at mine now
Thanks for saving me the hassle.
James.
Electrical Systems/Wiring
16
Jun 15, 2014 09:16 AM
redlightning93
Feb 3, 2009 12:11 PM
mudinford
Jan 13, 2006 08:59 AM
roddz170
1983 - 2012 Ranger & B-Series
Mar 9, 2005 07:58 PM
raidersiowa
Nov 8, 2003 10:27 PM
