Starter bolt help
Old Feb 12, 2014 | 05:02 PM
96f-150's Avatar
96f-150
Starter bolt help
This has been a rough few weeks. 2 batteries, alt., belt tensioner, hpop o-rings, and starter. While installing my newly rebuilt starter the bottom bolt stripped out.
A couple years ago I had the loose bolt problem but it's been good since. Is a helicoil an ok fix or is there something better?
Old Feb 12, 2014 | 05:11 PM
Pikachu's Avatar
Pikachu
A helicoil is fine, but if you don't already have the tools for them, it can cost you up to $60 or so by the time it's all over.
Old Feb 12, 2014 | 05:17 PM
m-chan68's Avatar
m-chan68
Or you can pull the transmission and flywheel to change the rear cover.
Old Feb 12, 2014 | 07:12 PM
F350-6's Avatar
F350-6
What are you doing slumming it down in the 7.3 section? Must be a slow week in the problem motor section for you to comment on a starter bolt in a 7.3
Glad to see your input down here either way.
Old Feb 12, 2014 | 08:55 PM
crop harvester's Avatar
crop harvester
they probably process a lot of applicants to work there.
Old Feb 12, 2014 | 09:50 PM
96f-150's Avatar
96f-150
Does anyone know the thread size and pitch for the starter bolts?
Old Feb 13, 2014 | 07:48 AM
riverrat41's Avatar
riverrat41
10mm x 1.50mm pitch 40 mm long
Old Feb 13, 2014 | 08:23 AM
96f-150's Avatar
96f-150
Thanks. the local ford dealership needs the last 8 digits of my vin to sell me two bolts.
I have a denso starter so does that change anything on the length?
Old Feb 13, 2014 | 09:30 AM
riverrat41's Avatar
riverrat41
I am not sure about that.I have the Ford gear reduction three bolt starter.
Pull one of yours out and measure the length you need.
I bought the bolts at a local parts store myself.
Old Feb 13, 2014 | 03:27 PM
89LX306's Avatar
89LX306
I have a helicoil set from when I stripped a starter bolt hole as well. I'll double check it when I get home to make sure I still have everything. I'd be willing to let you use it, just ship it back when you are done. We've all had rough weeks. Shoot me a PM if interested.
Kyle
Old Feb 13, 2014 | 03:37 PM
96f-150's Avatar
96f-150
Kyle
This is what makes this place great. Thank you very much for the offer, but I already picked a kit up on the way home. Figured it's something I should have around.
Old Feb 13, 2014 | 03:44 PM
89LX306's Avatar
89LX306
Not a problem. I like to help when/where I can.
Old Feb 13, 2014 | 06:53 PM
lhud's Avatar
lhud
I installed a new "real" Denso starter and used the same OEM bolts. Should be fine unless you get some knock-off Denso style.
ocracokenc
May 9, 2017 09:46 PM
tbirdage
Oct 19, 2014 10:40 PM
CrewCabLongbox
Jan 7, 2014 12:59 PM
