front suspension question
Old Feb 12, 2014 | 11:28 AM
willmunny79's Avatar
willmunny79
Question front suspension question
I had my 1979 f 150 4wd in the shop for some work and was informed that I need a drag link and axle track bushings. Stabilizing bar bushings as well@ a little over 700$
I purchased a Haynes manual with the idea of making the repairs myself and it said "let a professional do these repairs".
I have basic hand tools and a driveway, do you folks agree with Haynes?
Old Feb 12, 2014 | 12:27 PM
turbohunter's Avatar
turbohunter
I did mine in the driveway with hand tools.
It's not a problem.
Old Feb 12, 2014 | 12:32 PM
gatorfor88's Avatar
gatorfor88
For about $100 and maybe 2.5 hours of time(less if you have air tools) it is really an easy fix.
Old Feb 12, 2014 | 12:43 PM
SC'79's Avatar
SC'79
just did all mine last weekend. Very easy to do, see if you can borrow air tools from a friend. Will make the job 10x easier
Old Feb 12, 2014 | 12:51 PM
arctic y block's Avatar
arctic y block
Rent a compressor and the air tools ya need. Ya will be a lot of money ahead
still will that quote.
Old Feb 12, 2014 | 12:55 PM
HIO Silver's Avatar
HIO Silver
Do it yourself and save tons of money... it's time to get yer hands a little dirty. If you get stuck we're here to help.
Find a level place to do the work when replacing the track bar bushings because the track bar centers the axle under the truck. If the truck is tilted, it'll go "boing!" and get cattywampus when the bolt is removed. Personally, I use a ratchet strap to hold the frame steady or to pull the frame over so the bolt can be reinserted.
Old Feb 12, 2014 | 01:44 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Hit up the local FTE WA state chapter for some "live action" help, you might get a few helping and advising hands. And a few tools to boot, buy pizza and have a wrench fest.
Just have all you need parts wise, all ready on hand.
What are "axle track bushings"...nothing, you probably need drag link and trac bar bushings.
Trac bar is notorious to having the mount bushing go bad and the mount holes wallered out a bit. Radius arms need a big socket and a cheater pipe to put on that 3/4 or 1" breaker bar.
Air tools make the world rotate better for you, and help get the job done faster.
Old Feb 12, 2014 | 02:14 PM
willmunny79
Thanks for the info guys, I will give it a go, I plan to go at it one job at a time. I plan to start with stabilizer bushings then drag link. If those are a success then the track bushings.
Old Feb 12, 2014 | 02:24 PM
gatorfor88's Avatar
gatorfor88
If you dont spring for the poly bushings and get rubber, put them in the freezer over night. Helps installation .
Old Feb 12, 2014 | 07:57 PM
tbear853's Avatar
tbear853
Drag Link is easy one you get joints separated using press or pickle fork. No realignment needed on a 78/79 F150 as tie rod remains.
Track Bar bushings are easy, you can get them in a kit with 14 pieces that include C bushings and radius arm bushings as well, or just the 6 piece track bar bushing kit (Moog has it in polyurethane, each bushing is two parts and there's a steel sleeve at each end). Got the polyurethane, they last and last.
Stabilizer bar bushings also easy.
mondaynever
1978 - 1996 Big Bronco
Jul 3, 2017 12:32 AM
993/4ton
Apr 16, 2009 07:56 PM
sunuvabug
Oct 27, 2008 09:52 AM
CruiserClass
May 20, 2008 10:29 PM
Saxsellers
Jun 13, 2001 08:00 PM
