AC Delete?
Old Feb 12, 2014 | 11:06 AM
jonnygorgo's Avatar
jonnygorgo
AC Delete?
Having spent too much time staring at my truck, I have been wondering if anyone ever removed the AC compressor? In three summers, I only wanted to use AC it once, and then, it did not work.
I realize it would not help the value of the truck.
Advantages?
Disadvantages?
I did this to my Taurus SHO and have to admit, I did not realize any difference. I guess I was hoping for better mileage.
Old Feb 12, 2014 | 11:15 AM
snakedoc's Avatar
snakedoc
i dont see any help in mpg.
i dont think the belt will work with out a pulley where the AC is.
Old Feb 13, 2014 | 08:50 AM
glockholiday's Avatar
glockholiday
It takes no effort to spin the A/C pulley if the coil is not engaged so I don't see the reason.
Old Feb 13, 2014 | 09:54 AM
SARDiverDan's Avatar
SARDiverDan
I believe Matt is referring to the possibility of having too much slack in the belt if that pulley is removed. Have never tried it myself but it does appear as though the belt may be just a touch too long if the pulley was not routed over the top of the A/C pulley.
Old Feb 13, 2014 | 06:32 PM
Tailgate77478's Avatar
Tailgate77478
With these trucks, you will get better gas mileage using recirculated A/C than opening the vents, or even opening the windows with the AC off. The load resistance of the A/C against this engine is less than the increased drag introduced by the aforementioned alternatives when it comes to MPG. Moreover, if the AC is turned off, I don't really see how removing the unit itself would magically help MPG. Certainly not anything noteworthy. Even if you could get a 0.5 MPG improvement (which would be huge), would it really be worth the time/hassle/devaluation?
It's been proven time and time again that the driver's technique and right foot have the greatest effect on MPG. Do a search on hypermiling techniques.
Just my two pennies. Make change if you need to.
Old Feb 14, 2014 | 07:38 AM
jonnygorgo's Avatar
jonnygorgo
I suppose this idea may stem from a memory of working on my first truck- a bare bones 1986 F-150 with a straight 6. You could climb in and close the hood to work on it in the rain.
With my SHO I had to find a smaller belt that worked.
Has anyone ever use a chainsaw with a 16" bar, then changed to a 20" bar? You notice the added drag on the motor, even when cutting small material. I realize a chainsaw is a high speed, low torque motor.
Anyway, I am not doing it!
childsplay
Mar 10, 2026 05:45 AM
Future_LEO
Modular V10 (6.8l)
Sep 19, 2011 09:02 PM
dogmad7
Nov 8, 2010 06:33 AM
Hybrid
1997 - 2003 F150
Aug 31, 2007 12:02 PM
Billy Bronco
1978 - 1996 Big Bronco
Oct 21, 2004 05:53 AM
