engine idles wierd
Old Feb 21, 2014 | 02:24 AM
marine09's Avatar
marine09
Actually, the cylinder does not need to be at top dead center for the valves to be closed. Only the intake would be closed. If you take the rockers off, the springs will close the valves no matter where the piston is.
Old Feb 21, 2014 | 02:29 AM
Brnfree's Avatar
Brnfree
True about removing the rockers, but wouldn't both valves be closed at the top of the compression stroke?.
Still, I wonder if TDC would provide any insurance?
Old Feb 21, 2014 | 02:54 AM
marine09's Avatar
marine09
It would be hard to get it right at tdc to have both valves closed. The rockers are more of an insurance
Old Feb 21, 2014 | 09:21 AM
Filthy Beast's Avatar
Filthy Beast
You could: Take out the spark plug and feed some rope into the cylinder, then get that piston at TDC.......if you don't have the air accoutrements.
I know most parts stores sell an "on vehicle" valve spring compressor.
Good luck.
Old Mar 13, 2014 | 08:17 PM
marine09's Avatar
marine09
Ok. Valve spring replaced. I also pulled the distributo to make sure it wasnt messed up. It was fine but i firgot to mark it. So i redropped it with the #1 cylinder at 10° btdc. Lined the #1 spark plug wire with the rotor and the truck started right up. But now she back fires through the carb on occasion and has lost a lot of power.
Old Mar 14, 2014 | 12:08 PM
Filthy Beast
Have you checked the timing again to be sure?
Plug wires in correct firing order?
Might want to re-check your carb settings with a vacuum gauge too, but after the timing is set right.
Old Mar 15, 2014 | 02:19 AM
marine09's Avatar
marine09
Yea i figured it was the timing. My timing light broke during a house move. I went and got one today and it was firing right at the atc mark. So i put it at 12° btc. Runs like a champ now. Thx for all the help.
Old Mar 15, 2014 | 07:11 AM
Filthy Beast
You're welcome. Good to hear you're up and running.
jacob_powerhouse
Sep 10, 2018 06:41 AM
maybemark
17
Aug 8, 2015 12:42 PM
fairhardware
Apr 9, 2011 07:47 PM
billyb
Apr 2, 2008 09:14 PM
