trans problem after new clutch
Old Mar 27, 2008 | 08:01 PM
billyb's Avatar
billyb
Help!! I have an 85 f150 transmission that is not working after a clutch replacement.
The tranny won't go into third or reverse, and will shift between first and second without clutch pushed in.I have driveshafts out, so I can test the shifting.
I believe that it is stuck in third, but it will shift through gears with engine off. It sat for 6 months.
Any help is appreciated.
Old Mar 27, 2008 | 08:45 PM
ctubutis's Avatar
ctubutis
Originally Posted by billyb
The tranny won't go into third or reverse, and will shift between first and second without clutch pushed in. I believe that it is stuck in third, but it will shift through gears with engine off.
I'm not sure what you're describing or concerned about... a manual transmission will generally shift between gears without the clutch pushed in and the engine not running, that's nothing to be concerned about. I'm assuming a 4spd + reverse but it really doesn't matter. Regardless, it won't go into third or reverse, I'm assuming with the engine not running? It kinda sounds to me like maybe you've got the shifter lever misplaced in the transmission (I'm somewhat familiar with a T-18)? Have you tried it with the engine running?
-chris
colorado, usa
Old Mar 28, 2008 | 03:23 PM
billyb's Avatar
billyb
Chris,
Thanks for reply. First , it will shift from first to second with the engine rinning, but clutch not in!! it is not engaging gears, but will move back and forth.
It is an rts, not a t-18 tranny. It was used for a short time .
I aaam trying to figure out shifter is in wrong, but I can't seem to get top off or see into shifter hole to see what is going on.
Old Mar 28, 2008 | 08:53 PM
ctubutis's Avatar
ctubutis
OIC, thanks for the clarification. I don't know what an rts transmission is but it still sounds to me like a problem with the gear shift installation into the transmission, I can't see how a mere clutch replacement would cause your problem any other way (assuming you didn't do any other work ont he tranny, you merely removed & reinstalled it as a complete unit).
-ct
Old Mar 28, 2008 | 09:37 PM
billyb's Avatar
billyb
The rts is a 4 speed top loader with turret type shifter on top. RTS stands for rail top shifter. Some think it is the srod unit.
I agree that it is probably the shifter, but I can't seem to get it to work.
Thanks for feedback.
Old Apr 1, 2008 | 04:27 PM
billyb's Avatar
billyb
any other ideas??
Old Apr 1, 2008 | 04:57 PM
uncle.stosh's Avatar
uncle.stosh
I've never heard of an RTS trans/shifter ever put in an F150, but it sounds to me like you have your shifter forks/rails out of whack.
I'd pull the top cover and take a peak if I were you. Something is not right.
Old Apr 2, 2008 | 09:14 PM
billyb's Avatar
billyb
I pulled the cover and all looks O.K., but I need to know what is my starting point for lining up gears to reinstall shifter.
