2000 6.8L V10 - Running Hot
I changed the water pump, Upper radiator hose and thermo stat cause they said it was running how. I took it for a drive and compared the readings on that truck to my truck which is a v10 but a F350 not a F250. The readings between both trucks are the same. Checked clutch fan and it seems to be ok.
Customer used truck and said the coolant was coming out of the reservoir tank and it ran hot again.
I checked it out. If I grab the throttle cable and yank it about a 1/4 to 1/2 throttle area and let go, the coolant level at the minimum mark drops down an inch or two and the rises about 4-5 inches up. After doing that a few times it came up and started coming out of the top of the bottle. it would drop down and come back up and over flow and few times by its self with out reving it.
any suggestions on were to start. The water pump did look like it was damaged by rust and bad pitting from them using straight water or not servicing the cooling system for quite some time.
suggestions on what to do, were to start?
air is in the sytem.. and the pressure of the coolant isnt letting it rise.. there is a very specific way to bleed those sytmes and is highly recomended when doing so.. If not this is the result.. poor cooling and overflow.. just take your time and do the right way and it wont be back in.. i did mine the fast way to and learned the hard way..
