The short of this post is, and I'm sure its been covered so forgive me, but what parts from the new Econoline interior can be swapped?? I found a wrecked 2011 being parted out and I have a 2008. I know the center console will fit but I am interested in the door panels. The power mirror **** is the only thing I see totally different? All help is appreciated.
The body is basically the same so in theory they should swap out pretty simple.
If nothing else look at the panel's mounting tabs, the corresponding holes in the door shell and compare your parts to see if it'll be as easy as we're thinking.
