Just plug it in. Only need it for about three hours before you plan to start the truck. I put mine on a heavy duty timer from home depot. Also, some folks have had issues when plugging into a gfci outlet. It would trip it. My garage doesn't have gfci so I can't verify.
Is it safe to leave on all night? Dont really want to get up at 3 am for a 6am departure, id never get back to sleep
I bought a 20 amp timer for mine, programmed to turn on 3-4 hours before leaving for work. I lay the cord over the drivers mirror so I don't forget to unplug before driving off.
Ditto on both fronts! Don't want to drive off with the cord!
The 6.0 heater says it's something like 1000W, probably pulls more in the 850W range. Basically the equivalent of running your TV, stereo, living room lights, and an electric blanket all night. I don't like writing checks to the power company, so I use a timer.
well its 15deg out and I went out to start the truck and the oil temp was 46, cool beans! trans temp was 19......... Im guess the trans fluid dosent need a heater?
I took all you advice and strung the ext cord on my mirror as well
I had mine plugged into GFCI & it would sometimes trip, sometimes not.... So I plugged into a regular outlet and it works fine. Used the GFCI for my wife's Nissan
