99 Expedition EATC lights
Old Feb 11, 2014 | 02:19 PM
CBB9M's Avatar
CBB9M
What is required to fix burned out panel lighting on an EATC unit for a 98-02 Expedition EATC unit? I haven't fully dissassembled my unit but I've noticed that unlike the units used on 95-01 Explorers and 98-02 Crown Vics, the light bulbs are not on a twist and remove base. Does anyone know what is under the panel/button/display circuit board once it's removed from it's surroundings and if the lights are soldered in incandescent bulbs or LED's?
*We're talking the lighted buttons, and not the numeric/character display itself.
Old Feb 12, 2014 | 07:51 PM
CBB9M's Avatar
CBB9M
Bump.
70 views so far and not one single person has had a panel light go out on their (97-02) Expy EATC unit, and they opened it up and looked at what's inside and how to fix it by themselves???
Old Feb 15, 2014 | 02:20 PM
pat49's Avatar
pat49
bulb replacement
2000 Ford Truck Expedition 4WD V8-5.4L SOHC VIN L
Vehicle » Heating and Air Conditioning » Control Assembly » Service and Repair » Control Assembly Bulbs
•Control Assembly Bulbs
REMOVAL
1.Remove the control assembly. For additional information, refer to Control Assembly-Electronic Automatic Temperature Control.
2.Unsnap the bezel and pivot it open.
•To replace the general illumination bulbs, unscrew the lamp holders and remove the bulb.
•To replace the HI/LO bulb, cut the wires close to the bulb base, splice the wires to the new bulb and wrap the splice with electrical tape.
INSTALLATION
1.To install, reverse the removal procedure.
alz
May 16, 2016 10:15 AM
96f150
1997 - 2003 F150
Sep 24, 2012 01:31 PM
grip1968
Dec 5, 2011 12:25 PM
kjsway
Dec 2, 2008 03:57 PM
