engine question that will probably make you angry
Old Feb 9, 2014 | 12:48 PM
filthy6's Avatar
filthy6
Just got a 56 f100 with 292 y block. know nothing about the Y. compression ranges from 110 to 125,( with oil squirted in the cylinders) except for #6 which is 55. Want to keep the engine running for a while until I can get an updated replacement. The impossible question is what could be the cause of the lowest cylinder from easiest/cheapest to the hardest/most expensive. What is the least invasive way to diagnose the problem. I don't want to throw good money after bad.Thanks for your understanding.
Old Feb 9, 2014 | 01:03 PM
raytasch's Avatar
raytasch
Believe Nothing
First thing I would do is check valve adjustment. Easiest fix would be if the valves are out of adjustment, a bit of time and set of valve cover gaskets. Worst case would be a broken compression ring that has scored the block, rebore, the works $$$.
Is the engine running?
What is dry compression.
I've found a compression test on an engine that has not run in years can be meaningless.
Edit: And BTW, unless the engine has been replaced, it is probably a 272.
Another edit: And welcome to the forum, since you have such a low post count.
Old Feb 9, 2014 | 01:06 PM
Giesterfarher™'s Avatar
Giesterfarher™
If the truck has been sitting for along time, you may be dealing with stuck rings. In which case, you MAY be able to free it up with Marvel Mystery Oil. That's the best case/cheapest scenario I can think of.
Other, more expensive possible scenarios are:
Scarred/gouged/rust corroded cylinder.
Broken rings.
Collapsed lifter.
Burned valve.
Stuck valve.
Burned Piston.
Dead Mouse stuck in exhaust valve. Okay, this one isn't very likely, but I have seen it happen twice. But that's one that would possibly clear itself up. Probably. Other things in this category are mud dauber wasps and other bugs that like dark secluded places to make their nests with mud. Again very unlikely, if the air cleaner and spark plugs were left in place when the vehicle was parked. But don't forget, they can still get in the engine through the exhaust system via an open exhaust valve.
Old Feb 9, 2014 | 01:10 PM
Steve's Avatar
Steve
Check the valve adjustment too.
I use the EO IC method, it's simple:
Pull valve covers and spark plugs, find a 0.19" feeler gauge.
With a socket on the crank bolt:
Rotate the engine until the #1 cyl exhaust valve just starts to open. Adjust.
On the same cylinder, rotate the engine until the intake valve is just starting to close. Adjust.
Move to the next cylinder.
Then re check your compression.
The y block is an easy engine to work on and parts are still available including aluminum heads and other high performance parts. Try John Mummerts web site.
Old Feb 9, 2014 | 01:14 PM
clintonvillian's Avatar
clintonvillian
Pull the head.........
Old Feb 9, 2014 | 01:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Rotate the engine until the #1 cyl exhaust valve just starts to open. Adjust intake valve on that cylinder.
On the same cylinder, rotate the engine until the intake valve is just starting to close. Adjust exhaust valve on that cylinder.
I think this is what you meant? (edits above)
For the purposes of this test (cranking speed compression), unless one of the valves on #6 has less than zero clearance, it's either a burned valve or a bad ring situation. Not really any point to checking all the valves yet.
Old Feb 9, 2014 | 01:43 PM
Steve's Avatar
Steve
Yup. Your edits are correct.
You have a point regarding the #6 cyl, but I would check 'em all anyway.
H'ed get a feel about how the entire valve train was working.
Old Feb 9, 2014 | 02:13 PM
filthy6's Avatar
filthy6
Thanks for the welcome. I have found this forum very friendly unlike a corvette forum I have used. I know why people hate vette owners. The dry compression was 5 lower than the wet in the #6 cylinder. I was "told" the truck was a daily driver. The engine runs pretty good at idle and low rpms but backfires at higher rpms and under driving conditions. I think it's a transplanted 292, maybe from '60 but have not located any numbers to verify.
Old Feb 9, 2014 | 02:33 PM
filthy6's Avatar
filthy6
It's kinda a funny story, I guess. Saw this truck on Ebay in my home town. Talked to the owner and decided not to go look at the truck because I knew I would want it no matter what shape it was in. A friend who knows cars/trucks told me to stay away from it. He doesn't follow the crazy prices of the '56. I watched the last minutes of the auction only to see the final price so I could tell my friend how it ended. Did I mention I was drinking bourbon? In the last eight minutes I made a one time $100.00 BUMP just to watch the bidding take off. IT DIDN'T. I spent the next eight minutes yelling NO, NO, NO, NO! You know the ending. Believe it or not my wife is thrilled because now she doesn't have to look for a '56 everywhere we go.
Old Feb 9, 2014 | 03:00 PM
Giesterfarher™
Puts me in mind of a kid I knew that poked Hornets nests with a short stick, just to see what would happen.
Old Feb 9, 2014 | 07:08 PM
Steve's Avatar
Steve
The engine may be nursed to run just fine. I'd definitely adjust all the valves, to give it all the advantage you can.
Is there oil on the valve train and maybe some oil .pooled in the head? That would be good because the Y block family flaw is that they get dry up there.
You say it backfires at high rpm. Checking the ignition timing won't cost anything, so I'd be setting that to about 5 or 10 degrees. Is this an original points distributor? If so set the points first or just replace them.
Check the carb float too if it's easy. Change the fuel filter if it's not pretty new looking.
You can do all that for less than $30 including valve cover gaskets.
Old Feb 9, 2014 | 07:17 PM
The Horvaths's Avatar
The Horvaths
Turn it so that #6 has both valves closed. Connect an air line and feed a small regulated air flow to it. Listen to see where the air is escaping.
Double-check to make sure that there isn't so much air flow that the engine turns until a valve opens.
This will let you know if you have a valve/head issue or a ring issue.
Before going this far, how'd the spark plug for #6 look?
Old Feb 10, 2014 | 10:39 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Welcome filty56. I agree with the pull the valve cove recommendations. Too many things that could be your problem, seeing the valve train operate eliminates many of them. Valve cover gaskets are cheap and pretty easy to get and change. Valve, points and timing adjustments are all free except for your time. While some claim Seafoam or Marvin's Magic Mystery oil are nothing more than Snake Oil many on this forum swear by it and it's under $20. I've never heard of anyone claiming it ruined their engine, so it's a crap shoot if it will fix anything, but it won't hurt anything on the flip side. Good recommendation about shooting air in the cylinder and listening. OBTW you can run the engine with out valve covers, it just gets a little messy if you have a good oiling motor and then you can see if your engine is oiling well. Keep us posted and post some pictures
caleb1563
Jul 6, 2011 05:46 PM
Greenmillwork
Feb 23, 2009 11:17 AM
tcbofade
May 31, 2006 08:46 AM
walterperu
Mar 17, 2006 12:36 AM
azf150ford
Mar 13, 2006 07:25 PM
