door hinges
Old Feb 8, 2014 | 11:04 PM
joshofalltrades's Avatar
joshofalltrades
door hinges
on my e350, the front door hinges are pretty well FUBAR'd, and i'm looking into replacing them. google says new hinges don't exist, but a kit with a new pin and bushings does exist. are these any good or is it better to just grab a better set from the local junkyard?
at this point, the drivers lower hinge has one of its bronze bushings worn all the way through and popped up and out of place, and the passenger lower hinge is funny enough that to get it to start closing requires excessive force to pop it over a hump before it'll close the rest of the way smoothly. the bushings are still intact on that side but heavily worn. its bad enough that my wife often can't close the door for herself.
here's an example of the repair kits Dorman 38464 Door Hinge Pin Bushing Kit | eBay
so repair kits or used hinges? or install repair kits in better used hinges than i have?
Old Feb 9, 2014 | 06:30 AM
JWA's Avatar
JWA
Your E350 is pre-92 right?
If so that bushing/pin kit might be the best answer---certainly easy to locate.
I'd have to think on eBay or somewhere there is a NOS set of hinges, depending on which door you're working on. If its the drivers door those might be tougher to find since they're almost always the most frequently worn out.
The Dorman kit looks great---bushings, shoulder bolts and nuts too---might be a lot better than new in fact. This is assuming your current hinge pin holes aren't wallowed out. Even if they are maybe finding a good set of used then adding the bushing kit before installation might be the best bet.
If you go the bushing repair please let us know how it works out, maybe a short write up? Could be helpful to someone else facing this same situation.
I myself buy new since they're still available ('03 E250) and I'm a glutton for punishment----they're not easy to change by yourself!
Old Feb 10, 2014 | 12:07 AM
joshofalltrades
yeah, new doesn't seem to exist even on ebay for my hinges, even used is slim pickings. i think i'll go ahead and pick up used lower hinges for both doors from a local junkyard, then go ahead and put the dorman kit into all 4 hinges on my front doors.
the factory hinges have a steel pin with the head formed like that of a rivet, so it'll probably have to get cut off in some form (grinder, etc) or even just cut the center of the pin and slide the halves out top and bottom. then its just a matter of driving the bushings out and in. it looks like it should be a pretty straightforward task, and i'm hoping i might possibly be able to do it in position so i don't have to think about re-aligning my doors in more directions than necessary.
in any case, i'll post with how the job went once i get my hands into it
Old Feb 10, 2014 | 06:30 AM
JWA's Avatar
JWA
I have read a post (not here) about re-bushing door hinges and its said removing them can be a real bear. As I recall the poster did it on-vehicle, ending up using an air chisel with pointed bit to drive them out. That makes sense because heat while still on the body could add a whole new dimension of "Oh crap!"
If you have time to post some photos that'd be great!
Old Feb 10, 2014 | 12:33 PM
ceetwarrior's Avatar
ceetwarrior
If you do one at a time and have a buddy help you support the door, you wont have to remove the door or hinges to replace 'em.
Doorman 38467 http://www.summitracing.com/parts/rn...-250-econoline
winginit
May 13, 2015 09:13 AM
Uni Moe
13
Mar 27, 2014 07:10 PM
cberger627
Sep 16, 2009 02:58 AM
pluto1
17
Nov 28, 2005 01:12 PM
BigBadWally
Dec 15, 2003 10:20 PM
