Bronco II Ford Bronco II
Engine swap?
Old Jun 29, 2003 | 01:53 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Question Engine swap?
I have a 89 BII that has a better engine in it then my 88,I know that the wireing is different in the 2 trucks.I was wondering if the 89 engine will be a direct change to the 88?I was going to use the intake off the 88 (its the big throttlebody) on the 89 engine will this work? Also If I can find 1 which oil pump is the best ,high pressure or the high volume??KenOO
I know this is not just a BII ? so I will undrtstand if you move it.
Old Jun 30, 2003 | 10:36 AM
Ken00's Avatar
Ken00
Engine swap?
I think the 88 has EGR which the 89 doesn't, I think the spot is just covered with a plate.
Old Jun 30, 2003 | 05:41 PM
GrayRanger4x4
Talking Engine swap?
Is there anything else that I need to know about this swap? Thanks Ken00!!!!
Old Jun 30, 2003 | 06:21 PM
Willy McCoy's Avatar
Willy McCoy
Engine swap?
I'm not for sure, but I believe that the 89 also doesn't have a smog pump system either.
Old Jul 1, 2003 | 06:11 PM
GrayRanger4x4
Engine swap?
Thanks for the info .The 88 nor the 89 have a egr that I can find or a air pump.I dont think the FI motors have air pumps. Thanks!
Old Jul 2, 2003 | 02:44 AM
84bronco2's Avatar
84bronco2
From: I live in the beautiful state of hawaii, on the island of Oahu
Engine swap?
Hi guys I am new to FTE....I just recently aquired an '84 ford bronco 2....It was runngin good until i took it offroading in the hills....the motor already had 260,000 miles on it....but the body is in good shape...I am considering droping a 302ci in it...
1. How difficult is it?
2. Can i use the stock transfer case
3. Where can i find a book on this
Any other help you can give would be greatly appreciated
MAHALO from Hawaii
Avanti
Bronco II
May 28, 2009 01:14 PM
troys88BII
Bronco II
Mar 5, 2007 08:43 PM
BII Plow Truck
Bronco II
Jan 29, 2007 04:21 AM
GrayRanger4x4
Bronco II
Sep 29, 2003 07:54 PM
