I have a 89 BII that has a better engine in it then my 88,I know that the wireing is different in the 2 trucks.I was wondering if the 89 engine will be a direct change to the 88?I was going to use the intake off the 88 (its the big throttlebody) on the 89 engine will this work? Also If I can find 1 which oil pump is the best ,high pressure or the high volume??KenOO
I know this is not just a BII ? so I will undrtstand if you move it.
From: I live in the beautiful state of hawaii, on the island of Oahu
Engine swap?
Hi guys I am new to FTE....I just recently aquired an '84 ford bronco 2....It was runngin good until i took it offroading in the hills....the motor already had 260,000 miles on it....but the body is in good shape...I am considering droping a 302ci in it...
1. How difficult is it?
2. Can i use the stock transfer case
3. Where can i find a book on this
Any other help you can give would be greatly appreciated
