6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Extra Heavy Duty Alternator Question
Old Feb 8, 2014 | 07:14 PM
Movingsolution's Avatar
Movingsolution
My battery light came on driving from downtown the other day. Tuner read that it was putting out 14.3 V when I left and by the time I parked it was putting out only about 11.5 V. Went to start it to move it to a warm garage (Winter is being brutal with temperatures in Chicaaago) and had nothing.
Have since pulled batteries to charge them.
I'm pretty sure from the code I pulled it needs the alternator replaced. I have read mixed reviews on the forums saying the 6.4 is picky about what alternator you replace it with. Do I need to get a Motorcraft replacement in order for it to not throw any codes?
It has the Extra Heavy Duty Alternator (200 Amp) single.
Thanks. Having a rough winter so far with the truck here.
Old Feb 8, 2014 | 07:39 PM
senix's Avatar
senix
Get the M/C one. Aftermarkets tend to be hit or miss.
Old Feb 14, 2014 | 04:38 AM
ssharber's Avatar
ssharber
I had to replace mine and could not find an aftermarket one. Had to pay 400.00 plus just for the alternator then I put it in by myself. Really wasn't as bad to install as I was thinking it would be. Good luck.
Old Feb 19, 2014 | 02:27 PM
Movingsolution
$400 + core charge later it's fixed.
It was actually easier than the shop manual said. I was able to just remove the inner fender guard and then reach my arm in-between the fan and loosen up the belt. Then 4 bolts later alternator came out. Installation was even easier.
Just hope this one lasts at least as long as the first!
scottsmith
Sep 4, 2018 08:29 AM
Ponyboychris
40
Oct 8, 2008 01:24 PM
nathan5603
1983 - 2012 Ranger & B-Series
Aug 11, 2008 12:26 PM
schmidt64
Dec 12, 2007 08:37 AM
ganluin
Aerostar
Sep 17, 2007 07:39 PM
