No spark at distributer
Old Feb 10, 2014 | 09:29 AM
fmc400's Avatar
fmc400
MSEE
Glad to hear it's moving forward. What specifically are you jumping on the solenoid to keep it running? I assume the battery post to the 'S' post? Does that mean the starter stays engaged during the brief period you keep it running?
Old Feb 10, 2014 | 01:10 PM
benbuilder's Avatar
benbuilder
Yes, this is exactly what happens. The engine will only stay running if I have made this contact. Is this normal? I can try to chase down all the wires to the ignition and try to use this. In any event, We got the engine running. I replace the coil and still had no spark at the plugs. I lifted the wire arm on the rotor so it made contact with the distributer and then it started to fire. Thanks so much. You are patient.
Old Feb 10, 2014 | 02:50 PM
cbenz73's Avatar
cbenz73
See you have a separate circuit that is used for ignition during starting, because of the voltage drop during the large amperage draw.
Old Feb 10, 2014 | 03:21 PM
fmc400's Avatar
fmc400
MSEE
If the engine fires while the key is held in START, but shuts off as soon as the key is released to RUN, it's an indication that the ballast resistor is open circuit, or the ignition switch is failing.
Turn the key to RUN without starting the engine, and measure the voltage at the positive terminal of the coil. Report your results.
Old Feb 17, 2014 | 07:01 AM
benbuilder's Avatar
benbuilder
My problem is that I am starting the truck from the solenoid. I am jumping the battery post to the 'S' post. The engine will run as long as these two are connected. I do not have the keys to this truck. Is this normal not to keep running from the solenoid? I will get another ignition switch if needed.
Thanks
Old Feb 17, 2014 | 07:33 AM
fmc400's Avatar
fmc400
MSEE
No, it's not normal. The engine should be able to run without the aid of the solenoid (otherwise the starter would grind into the ring gear the entire time the engine is running). See my above post for the two possible culprits. The test I described is a good starting point to help determine which.
Old Feb 17, 2014 | 07:51 AM
Don Senkow's Avatar
Don Senkow
If you haven't any keys, how are you turning the ignition on? Jumping from the battery terminal to the S terminal will turn the engine over and through the ignition ballast resistor circuit will fire the engine That is what it is supposed to do. With the key in the run position, do you have voltage? That question, I believe has been asked. If you don't have a key, did you measure the voltage at the coil +?
Run a jumper from the Battery positive to the Coil +. Then try jumping the Battery to the S terminal. If it starts and runs, you must repair the ignition run circuit. Don't leave it like this as the points will burn after a few minutes.
Old Feb 17, 2014 | 08:08 AM
fmc400's Avatar
fmc400
MSEE
That's a great point. I missed the part about the keys missing. For the engine to keep running after the jump is removed, the key needs to be left in RUN. Maybe this is a good time to have the keys made, since you'll need them anyway. A locksmith can make a key from the tumbler pins if you bring in the tumbler. If the truck is all original, either door and the ignition should be the same. Since you need the key to take apart the ignition switch, the door would be the best bet.
Old Feb 17, 2014 | 01:55 PM
benbuilder's Avatar
benbuilder
Thank you both.
Culprit83
Jul 10, 2016 10:34 PM
micah350x
Jul 9, 2007 10:47 PM
irontruck
Apr 19, 2005 12:03 AM
Ken S
Electrical Systems/Wiring
May 19, 2004 09:44 PM
raywa
Mar 10, 2003 09:02 PM
