Fuel pressure problem?
Old Feb 7, 2014 | 10:35 PM
jcalebw's Avatar
jcalebw
I have an airdog 2 165gph going to a regulated fuel return. When I start if lt goes to 45 then 55 then 60psi then just drops to 45 I tryed to find a leak no luck. When I turn down the pump it just can drop to zero
Old Feb 8, 2014 | 07:16 AM
npccpartsman's Avatar
npccpartsman
What kind of regulated return do you have? Balancing the regulated return with the ADII can be a bit of a trick.
Old Feb 8, 2014 | 08:32 AM
jcalebw's Avatar
jcalebw
Sinister diesel
Old Feb 8, 2014 | 09:19 AM
npccpartsman
Here's the way I set mine:
1) Turn the PUMP regulator all the way in and back it out about 3/4 turn. DO NOT tighten it down when turning it in. All it has to do is lightly touch the seat.
2) Adjust the fuel pressure regulator under the hood to 58 psi.
If you're having issues with the pressure not staying adjusted then using the AD2 instructions remove the fuel pressure regulator adjusting screw and the plunger/piston and check the small o-ring on the end. I'll bet it's split/broken. The pump comes with a spare one. Replace, install, and retest. You may have to adjust the fuel pressure screw a bit but remember that more pressure does NOT equal more fuel. It's more important to maintain the fuel pressure steady at 58 or 60 than have it at 70 and drop to 45 or 50 at WOT.
Old Feb 8, 2014 | 11:14 AM
npccpartsman
I just read a thread about this particular part failure on the AD2. If you can get a Viton O-ring sized a011 to replace it you'll be better off. Harbor freight carries a kit with several sizes for a very good price. ~$10
Old Feb 8, 2014 | 08:45 PM
jcalebw's Avatar
jcalebw
Well **** I cleaned the pump and now I have no fuel pressure
Old Feb 8, 2014 | 08:57 PM
jcalebw's Avatar
jcalebw
Lift pump good one?
I need a good lift pump?
Old Feb 8, 2014 | 09:35 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Cummins need lift pumps...
Josh
Old Feb 8, 2014 | 09:37 PM
jcalebw's Avatar
jcalebw
Fuel pump thing thst pumps fuel lol
Old Feb 8, 2014 | 09:51 PM
Bullitt390's Avatar
Bullitt390
What's wrong with the stock HFCM?
Josh
Old Feb 8, 2014 | 09:59 PM
jswartz84's Avatar
jswartz84
Josh
Haha my thoughts exactly.
Old Feb 9, 2014 | 05:53 AM
npccpartsman
You may need to loosen the water separator and key it on to get it to prime.
Old Feb 9, 2014 | 06:06 AM
jcalebw's Avatar
jcalebw
Doesn’t pump any fuel to the motor
Old Feb 9, 2014 | 06:09 AM
npccpartsman
So you have an AD2 feeding your stock pump??
Old Feb 9, 2014 | 06:17 AM
jcalebw's Avatar
jcalebw
No no airdog is just messed up and the stoxk before it messed
