Fuel pressure problem?
Old Feb 9, 2014 | 06:51 AM
Money-Pit's Avatar
Money-Pit
Old Feb 9, 2014 | 06:58 AM
npccpartsman's Avatar
npccpartsman
I'm going to try and get your threads merged so we don't get scattered back and forth.
Old Feb 9, 2014 | 08:46 AM
npccpartsman
Did you check the o-ring on the end of the fuel pump pressure regulator piston?
Old Feb 9, 2014 | 12:13 PM
jcalebw's Avatar
jcalebw
How do I check that pics if possible plz
Old Feb 9, 2014 | 12:27 PM
npccpartsman
The fuel pressure adjustment on the pump has a jam nut on it to keep the adjustment from moving. Loosen that nut and screw the adjustment screw all the way out. Inside you'll have a spring and a piston that's, IIRC, tapered on the end with an o-ring. Remove the spring and piston and check to see if the o-ring is damaged. Replace with one of the spares provided with the pump.
AFA not pumping fuel after you cleaned it, turn the key on and crack the water separator filter loose while the pump is running until you hear the pump motor change tone. You may have to key it on with the separator loose more than once until it picks up fuel. When you hear the motor change tone quickly snug the separator back on or you'll get a bath.
Old Feb 9, 2014 | 10:33 PM
jcalebw's Avatar
jcalebw
Fixed the problem thanks for all the help saved me $800 thanks again
Old Feb 10, 2014 | 04:13 AM
npccpartsman
If you continue to have a problem with that o-ring see my earlier post about putting a Viton o-ring in it's place.
Old Feb 10, 2014 | 07:15 AM
mustang_309's Avatar
mustang_309
Well????????? How did you fix it?
Old Feb 10, 2014 | 04:24 PM
jcalebw's Avatar
jcalebw
Did what he said
Old Feb 10, 2014 | 06:15 PM
npccpartsman
Did what he said
You're welcome. I had the same thing happen to a buddy's truck or I'd have never known what it was.
Old Feb 10, 2014 | 10:14 PM
jcalebw's Avatar
jcalebw
I bought new o rings for everything and reset the pump
rdunagan
Jan 28, 2022 12:40 AM
farmer ford
Apr 17, 2014 10:20 AM
hydro man 17
Jul 18, 2013 09:29 PM
96250XLT
18
Feb 11, 2011 06:09 AM
RdnckEMT25
Nov 2, 2010 07:42 PM
