BB in the fuel pressure regulator
Welcome to FTE!!!
The BB in the FPR (Fuel Pressure Regulator) will increase your fuel pressure. To answer your questions.
1. Is it true
YES
2. Are there any side effects
If you have a California Emmissions model, the BB will give it to much pressure and wear out your fuel pump prematurely. Cali models already have high enough pressure.
3. Would it be bad to put in two BB's
2 BB will make to much pressure and wear out the pump
I think no more than 60psi at the schrader valve.
More people will weigh in on this.
Here are some "Gotta have" links you should save:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Tips - Idea - Hints
97-15A 7.3L DI Turbo Workshop Manual
1996 Bronco/F-Series Workshop Manual
1. Is it true
YES
Tips - Idea - Hints
Before I put a new fuel pump in I was reading like 10 psi at the fpr with a harbor freight guage. Ive got a new pump on and my mileage has come up but I can't get a psi reading within normal limits. Granted I'm using a tire guage and plan to go get another actual fuel guage but if the results are not good what could be the culprit?
