94 f150 fuel line problem wont stay on pump
Old 02-07-2014, 09:34 PM
mattl468's Avatar
mattl468
mattl468 is offline
one of the fuel lines keeps coming off when i drive. The connector is a pain to get snapped on to the fuel pump. I would get it to snap on and then after a few days it would come off while i was driving. anyway to replace the connector or do i have to replace the whole line.
Old 02-07-2014, 09:56 PM
77_F150_4x4's Avatar
77_F150_4x4
77_F150_4x4 is offline
If it is the same connector as fuel filter(tool required to change, not plastic clip) I know napa use to sell the insert for them or you could try to straighten out the one you have.
Curtis
Old 02-08-2014, 07:10 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,172 Likes on 926 Posts
You can replace the spring inside the fuel line fitting. The lines should literally snap on, if you have to fight to get it on then the metal spring inside is messed up most likely.
pittmick
1997 - 2003 F150
04-05-2012 12:54 PM
Firescu
10-31-2011 06:19 PM
89F20plowtruck
05-18-2010 04:52 PM
dyoungen
12-22-2009 12:41 AM
fordtruck88
05-02-2008 05:34 AM
Quick Reply: 94 f150 fuel line problem wont stay on pump
