problem disconnecting fuel line
Old May 1, 2008 | 06:48 PM
fordtruck88's Avatar
fordtruck88
I am replacing the fron fuel tank on my '94 f150 4x2. I used the quick connect removal tool i got from autozone to get one line off. However, the tool won't work for the second, larger line on the fuel pump. Is there a different method that should be used to get this line off? Also, how do i get the electrical connection off the top of the fuel pump? When i tried to pry it off it didn't moe and just scuffed the plug.
Old May 1, 2008 | 07:01 PM
netscaner's Avatar
netscaner
There are two different sized lines that require two different sized tools or a 2 in 1 tool.
The electrical is usually a 4 lead pigtail about 8-10 inches long with a plug on the end. It doesn't unplug on the end that is attached to the fuel pump assembly.
Old May 2, 2008 | 05:34 AM
ri_truck_guy's Avatar
ri_truck_guy
Seat the tool on the garter spring, then push the line towards the tool. That usually works for me.
