Highboy speedometer correct
Old Feb 7, 2014 | 09:41 AM
big-ugly's Avatar
big-ugly
I ordered a set of turbine wheels for my highboy and some 37" hummer tires to match them. I need to know how I am going to correct my speedometer. Surely with all of the people out there running these tires, someone has corrected their speedometer. If I am understanding all of my findings, then a 16 tooth driven gear is the fastest gear offered by Ford. How close would that get me to being accurate? Searching has been nearly fruitless for me.. Any help would be greatly appreciated.
Truck is a '74, has 4.10 gearing, np205 xfer case, and an np435 4-speed.
Old Feb 7, 2014 | 11:50 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do you see the blue line with User CP, Albums, FAQ? See the search on that line?
It has a drop down search menu arrow, go to the "Advanced Search" option, type in there say "blab la bla" and then go to the lower right column and high light 73-79 forum.
Select it and then you will have a detailed search just in the 73-79 forums.
Post #4, and in here https://www.ford-trucks.com/forums/1...ease-read.html
And here is a great one
https://www.ford-trucks.com/forums/1...libration.html
Old Feb 7, 2014 | 07:35 PM
hoffy's Avatar
hoffy
you have to buy the correct speedo gear that matches your combo try lmc there is a bunch of different ones
Old Feb 8, 2014 | 10:00 AM
spikinfool05's Avatar
spikinfool05
where the heck did you find 16.5 anything around here?
Old Feb 9, 2014 | 02:25 PM
big-ugly's Avatar
big-ugly
Telling me how to search, after telling you that searching has proven to be useless does what exactly? Thanks for nothing..
hoffy, I know that I have to swap out my driven gear, and the fastest gear offered from anyone is a 16 tooth gear... that is why I asked how closely a 16 tooth gear would get my speedometer....
spikinfool, I ordered my tires from Tucson, AZ.
Old Feb 10, 2014 | 10:20 AM
77&79F250's Avatar
77&79F250
Well since you were so polite about it (insert sarcasm) I'll explain myself. I posted the directions on how to use the "Advanced Search" option because most people do not know about it, and it works great for me by the way.
Did you even bother to click on the very informative links I posted? FYI I got one of the links by using the advanced search.....
If I had the exact answer to your question I would of posted it. But since I did not I thought I would at least try to be helpful and give you some helpful advice to maybe find the answer, with your reply, guess it was not.
Hope it works out for you.
Old Feb 10, 2014 | 10:31 AM
jgavac's Avatar
jgavac
There are still a few out there. Humvee tires being one option. But for the most part, they're all north of the 37" range
I'll keep an eye on this, because I'll be getting some 35's in the near future and will be interested in knowing the answer
-Jameson
Millam
May 1, 2018 05:31 PM
dreadinger
Jan 17, 2009 09:55 PM
Douglas Walker
17
Dec 19, 2006 06:21 PM
YoungMT Hick
Aug 20, 2006 09:13 PM
