weak steering in an Econoline E350
Old Feb 7, 2014 | 09:03 AM
schluchtenflitzer's Avatar
schluchtenflitzer
2001 E350 7.3L PSD converted to 4X4 with an `06 F250 front wit 34" tires.
Here's the problem: With my foot on the brakes and at a full stop, the steering is very hard to turn. Like it's binding up or something.
When the brake pedal is released the power comes back to the steering. First I said it was the pump of course. Replaced the pump....same problem. This only occurs when the brake is applied firmly and sitting still. Everything is fine when the truck is in motion. No brake or steering problem at all.
I checked all bearings and links several time. If i lift the front i can move from left to right just pushing the tires, so nothing goes hard there.
Van has an vacuum pump for the brake and a hydraulic for the steering.
Can anyone advise me on this issue?
All comments and ideas are welcome.
Old Feb 7, 2014 | 11:13 AM
Tim Hodgson's Avatar
Tim Hodgson
Willkommen schluchtenflitzer!
I don't know if this answers your question but it may be helpful:
https://www.ford-trucks.com/forums/8...-steering.html
Hopefully someone more knowledgeable than me will be along soon...
Old Feb 7, 2014 | 11:39 AM
schluchtenflitzer
Hopefully someone more knowledgeable than me will be along...
I have no hydro boost in my van, it is a vacuum system.
And i forgot to say that it does not help if i rise up the rpm´s. Absolute no different to normal rpm`s
Old Feb 7, 2014 | 11:43 AM
Tim Hodgson
You know that I have a van as well, and when I was posting the link above, I was thinking, hmmm... do I have a hydroboost?
We also both have 7.3Ls but since we don't have hydroboost like the F series, I suggest that you also post your question in the full size van forum here:
1968-2013 Full Size Vans - Ford Truck Enthusiasts Forums
Old Feb 7, 2014 | 12:28 PM
schluchtenflitzer
Thanks Tim, great idea
i did not know the van forum here...
Thanks for the support
Old Feb 8, 2014 | 05:52 AM
JWA's Avatar
JWA
Without hydro-boost brakes there's no conceivable reason steering should be affected.
Assuming the PS pump belt is properly tensioned I'd have to wonder if something in the steering box itself isn't causing this? Perhaps a restriction in one of the pump hoses or passages in the box?
Even as I write that though it still baffles the hell outta me too!
Sorry I can't be more help.
petecal
Nov 26, 2014 09:08 PM
schluchtenflitzer
Feb 9, 2014 10:42 AM
scarl
Aug 22, 2003 05:11 PM
