wear steering
Old Feb 7, 2014 | 12:25 PM
schluchtenflitzer's Avatar
schluchtenflitzer
wear steering
2001 E350 7.3L PSD converted to 4X4 with an `06 F250 front wit 34" tires.
Here's the problem: With my foot on the brakes and at a full stop, the steering is very hard to turn. Like it's binding up or something.
When the brake pedal is released the power comes back to the steering. First I said it was the pump of course. Replaced the pump....same problem. This only occurs when the brake is applied firmly and sitting still. Everything is fine when the truck is in motion. No brake or steering problem at all.
I checked all bearings and links several time. If i lift the front i can move from left to right just pushing the tires, so nothing goes hard there.
Van has an vacuum pump for the brake and a hydraulic for the steering.
it does not help if i rise up the rpm´s. Absolute no different to normal rpm`s
Can anyone advise me on this issue?
All comments and ideas are welcome.
Old Feb 7, 2014 | 03:40 PM
Cobra-Kai's Avatar
Cobra-Kai
How wide are your tires and what offset do the rims have?
Maybe the front tires are too wide apart from the actual turning point and need to spin a bit on a radius
Old Feb 8, 2014 | 03:56 AM
schluchtenflitzer
I think that is exact the problem! But...I have a F250 front with 0 bachspace wheels and no spacer. I think that is a constelation that works on other trucks well?
Old Feb 8, 2014 | 06:49 AM
JWA's Avatar
JWA
Since this condition exits stopped with brakes applied does it repeat itself on a flat surface in neutral, brakes off?
Old Feb 8, 2014 | 06:52 AM
Cobra-Kai's Avatar
Cobra-Kai
Didi, Solange wir hier unter uns sind frag ich mal so :
Stehen die Räder in gleicher Flucht mit den Radnaben oder stehen sie weiter außen?
Die Auflagefläche der Reifen sollte auf gleicher Höhe mit dem Drehpunkt der Naben sein.
Old Feb 8, 2014 | 09:26 AM
schluchtenflitzer
No than it works.....hard work to steer but wheels are turning
Old Feb 8, 2014 | 09:29 AM
schluchtenflitzer
Ja ist einfacher Kai ;-)
Nein der Drehpunkt ist schon weiter außen, aber es gibt wohl einige andere die die selbe achse/Felgen drauf haben und bei denen funktioniert es. Angeblich habe ich eine 06er F250 HD Vorderachse eingebaut. Ich weiß allerdings nicht was die so für Felgen ET fahren.
Old Feb 9, 2014 | 06:55 AM
JWA's Avatar
JWA
^^^That's all Greek to me!
Old Feb 9, 2014 | 10:42 AM
Cobra-Kai's Avatar
Cobra-Kai
Allright JWA I'll try to translate what "Gorgerunner" and I wrote, for you :
I:
Are the Wheels in one line with the hubs or are they further outside?
The contact surface should be in one line with the hubs.
Schluchtenflitzer:
No, the turning point is further out, but there are some who have the same axle/rim combo and it works.
Supposedly I got a '06 F250 HD front axle build in.
But I don't know what's their rims offset is, they're driving.
schluchtenflitzer
Feb 8, 2014 05:52 AM
gjcst
Nov 18, 2007 08:43 AM
toa5150medic
Aug 25, 2007 01:44 AM
gcozmo
Jan 7, 2006 07:31 AM
The Fedex Man
Dec 3, 2003 05:00 AM
