Mean green
Old Feb 6, 2014 | 08:56 PM
brandon.edwards's Avatar
brandon.edwards
Mean green
Anyone runnin a mean green 220 amp alternator in their 6.0? What do you think of it. Do you have specs of the alternator?
Old Feb 7, 2014 | 04:32 AM
Nice Work Truck's Avatar
Nice Work Truck
I have had one for about 2 years now and it has been good.
Old Feb 7, 2014 | 04:52 AM
brandon.edwards
Do u know the idle amperage? Do u run anything extra on ur truck/ work truck? I run a plow, spreader, lights etc and was wondering if this alternator is good for that
Old Feb 7, 2014 | 05:11 AM
Nice Work Truck
I think the idle amps are about 120.
If I was running all that stuff I would go with a DC 270 alt.
https://www.dcpowerinc.com/vafproduc...rstroke+Diesel
Just make sure you also upgrade your wiring.
Old Feb 7, 2014 | 08:33 AM
brandon.edwards
What all wiring should I upgrade? Is it really necessary?
Old Feb 7, 2014 | 01:12 PM
npccpartsman's Avatar
npccpartsman
You should at LEAST upgrade the alternator to battery cable. The stock wiring is not really rated for that many amps. IMHO you're just wasting your $$$ if you don't.
Old Feb 7, 2014 | 02:15 PM
mhoefer's Avatar
mhoefer
Actually, on my 230 amp Prestolite, you have to upgrade the charge cable to 2/0 and the ground from the alternator to the passsenger batter with 2/0. If you push to much amps through that stock cables, it will melt the fusible links and you will likely end up with a fire if anything positive touchs ground. I agree, do the wiring properly for these kinds of amps or the alternator cant push all that power to the batteries.
I looked them up, they are new, but they dont specify all the components, you have to trust they are all top grade, versus the DC Power and the Prestolite, I thnk they are a gamble. The reason I went with the prestolite is warranty at all international vehicles, and every LCF with a VT365 uses them. They are a well known, trusted heavy truck supplier.
Old Feb 7, 2014 | 02:45 PM
brandon.edwards
Ok so ill upgrafe the chArge that and ground both to 2/0. Those 2/0 cables I ought to be able to get at the average auto part store.
Old Feb 7, 2014 | 02:59 PM
Nice Work Truck
You should upgrade the cable from the alt to pass. battery, pass batt to driver batt.
Also do both grounds.
With a 270 amp alt I would run 2/0 as I did.
I have heard good things about this place for cables.
Heavy Duty, Aftermarket, Custom Battery Cables for your Car, Truck or RV
You can see the 2/0 cables that I put i mine.
Old Feb 7, 2014 | 03:10 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Most CF400/500 trucks received either the normal 110 6G or the 160 amp Visteon.
The Prestolite 230 amp is an optional upgrade that debuted in 2011.
Josh
jbrune
Jan 9, 2015 06:15 PM
Patrick Musick
17
Oct 11, 2014 07:22 PM
ac700wildcat
39
Dec 16, 2010 02:48 AM
tomfg
Feb 7, 2007 10:27 PM
Dave
Jan 17, 2000 01:24 PM
