Hi I'm a newby and I have a questiiion.. this weekend I installed a coolant filtration system and a oil bypass filtration,, changed both fuel filters, added archoil into the oil filter stand pipe hole, and transmission. also loaded a custom tune from mpt... all this was done on my 2005 f350 dually cc sb. as well as a blue spring upgrade three weeks ago. drove to work for two days to let the new tune learn... its been in the 30* to 40* range here . but my truck runs fantastic when going slow,,,,, but when i give it some coal,,, it sputters a bit then takes off.... ect 179 eot 192 air filter has 11,000 miles on it. also noticed today on the oil bypass filter ... it seems to be leaking a little at the top of the filter. I put it on a little tight before i installed it.... need to stop leak and sputter ....
Put the stock tune back in to rule out programming, check the lower fuel filter cap to make sure it's not leaking air (surprisingly common), load test the batteries, and test the FICM: https://www.ford-trucks.com/forums/8...procedure.html
