Aerostar Ford Aerostar
Cabin Hatch Removal
Old Feb 6, 2014 | 09:19 AM
57t-bird's Avatar
57t-bird
Cabin Hatch Removal
Is there something else hold the cabin hatch (doghouse) in place? I've unsnapped 3 latches but it still refuses to come loose.
Old Feb 6, 2014 | 12:44 PM
Jose A.'s Avatar
Jose A.
try looking under the center dash trim, (below the ashtray and the cubby cavity), there's a black box for the anti-lock brake system held by two 8mm nuts, and also if you remove the cupholder mounted to the floor it helps it to come off easier.
Old Feb 6, 2014 | 08:59 PM
xlt4wd90's Avatar
xlt4wd90
There are only 3 latches, and once you unlatch them, the cover should at least come loose. If not, it's probably glued to the seal, and will take some gentle prying. If you have a floor shifter, you need to put that into low 1 gear to make space for it to come out. I usually pull the lower edge up and back a little so its upper part will clear the bottom of the dash.
ntxlandman
Jun 11, 2009 05:48 PM
SRatta
2004 - 2008 F150
Dec 4, 2006 02:08 PM
rickauf
2004 - 2008 F150
Oct 21, 2005 08:23 PM
pollok
Aerostar
Mar 26, 2004 03:03 PM
TheMachfather
Jan 18, 2004 11:49 PM
