Gauge cluster
Old Feb 6, 2014 | 12:51 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Its all good , just trying to help. And sorry I forgot to include the "lol" after it.
Old Feb 18, 2014 | 01:55 AM
Buggz_14's Avatar
Buggz_14
Hey guys!! I've been busy with work and haven't had time for my truck but I had a little time today and I unplugged the voltage regulator. Alt. Light turns off when disconnected.
Old Feb 18, 2014 | 12:06 PM
fmc400's Avatar
fmc400
MSEE
Based on your statements and observations, your voltage regulator is partially bad, meaning it is able to pull the alternator online and facilitate charging, but the internal mechanism for shutting off the ALT light has failed. This is less common but does happen.
The regulator is the only place the ALT light can get grounded such that it turns on (your latest test indicates there's no external short). If replacing the regulator does not keep the ALT light off, then the problem has not been described to me accurately. There's no way you can maintain 14.4 volts without the regulator at least partially alive.
highway90
Sep 17, 2017 07:41 PM
Jklnhyd
Jan 3, 2014 09:21 PM
OregonGuy1978
Apr 3, 2010 10:46 AM
BJScott1986
Electrical Systems/Wiring
May 5, 2005 11:21 AM
djtdaveboy
Oct 25, 2003 06:26 PM
