6.0 no start
Old Feb 5, 2014 | 09:49 AM
9228.bobcat's Avatar
9228.bobcat
Was that a used programmer or new?
Old Feb 5, 2014 | 09:53 AM
Garrthomp823's Avatar
Garrthomp823
It was a new programmer and I've done all the work on it, but it hasn't had anything done to it in a little while
Old Feb 5, 2014 | 09:56 AM
9228.bobcat
I would call edge up. They kind of had problems with those programmers jacking up the pcm.
Old Feb 5, 2014 | 09:57 AM
9228.bobcat
Do you have a scangauge or anything? You might reset your inertia switch. Take a second to do and probably not it but worth a try.
Old Feb 5, 2014 | 10:06 AM
9228.bobcat
I dont know alot about those programmers but dont they hook up to the pcm a box or something. If it does I would completely unhook it. Maybe a connection problem
Old Feb 5, 2014 | 10:14 AM
Garrthomp823
I'm going to call edge now, it just plugs into the obd2. There shouldn't be anything mechanical, the truck is solid and runs like a champ. I've read where those programmers can be temperamental until you get them set up right
Old Feb 5, 2014 | 10:32 AM
Garrthomp823
I talked to them and they said it could be ficm related so i guess ill test that next
Old Feb 5, 2014 | 10:38 AM
9228.bobcat
I if the truck ran percectly before and cant see it being a ficm issue. More likely pcm related with the edge. I would also check fuses.
Old Feb 11, 2014 | 08:18 PM
Garrthomp823
Okay just an update, I went and bought a scan gauge today and got it set up, and my icp was at zero, where would you all start?
Old Feb 11, 2014 | 08:26 PM
bismic's Avatar
bismic
Have you tried disconnecting the ICP and then cranking?
Old Feb 11, 2014 | 08:29 PM
Garrthomp823
Unplugged icp and cranked and it said 1894 pounds but still no start
Old Feb 11, 2014 | 08:31 PM
BLADE35's Avatar
BLADE35
program this and Take the value at KOEO and Post
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
Old Feb 11, 2014 | 08:32 PM
  #28
BLADE35's Avatar
BLADE35
And your taking the Values in STock Mode Correct????
Program this as well and Post BOTH codes at KOEO and CRANKING
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
Old Feb 11, 2014 | 08:39 PM
  #29
Garrthomp823
At KOEO I have .23
Old Feb 11, 2014 | 08:40 PM
  #30
Garrthomp823
I did reset back to stock, but am waiting on my batteries to charge back up so I can crank on it again
