Just installed my new edge evolution, I got my truck running and put it on the 60 horse tune, I revved it to about 3000 rpms then it died, I cannot get it to start back. It will crank and crank but I get nothing. I need help
Do you get Oil Flow to the Oil Filter housing when cranking with the drain held Shut??? If No Pull the LPO Regulator and clean it and housing its down by Crank shaft pulley
Seen this Exact senereo 1 time before and that was it GOOD LUCK!!
long shot but...
You could also call Edge & see if they could somehow make sure there isnt a programming glitch if it was immediately after a program, there C.S. is great (i run an Edge CS).
