'89 Ranger Clutch Help
Ever since I did the work the truck is a bear to get into 4th gear, meaning I have to double clutch and then it will still grind, etc. It also doesn't go into 2nd extremely well but a lot better than 4th. I am trying to find the solution for the problem but don't really know where to start.
When I installed the new clutch and slave cylinder I obviously had to disconnect the quick-disconnect from the old slave cylinder. After I did all of the work I bled the system using the bleeder valve on the new slave cylinder. Is it possible air got into the master when I pulled the quick disconnect?
I am thinking the problem is either air in the master or the aftermarket slave cylinder isn't an exact replacement. How do I know positively if there is air in the system? I have a full clutch pedal and if I have the tranny in neutral with the clutch engaged, then push the clutch pedal down, it will go into 1st with no problem. 1st, 3rd, and 5th will all shift throughout the course of driving perfectly fine.
Can anyone help me out?
Thanks!!
Ryan
http://www.therangerstation.com/tech...edclutch.shtml
If you can have the engine at idle, depress the clutch, and shift into 2nd and 4th without any grind or harshness, then the clutch is working properly. If you can start the engine, pedal depressed, in 4th and 2nd without trouble, the clutch is working.
If you cannot do the above, your clutch is not releasing properly. I read somewhere about a spacer put on some of the replacement slave cylinder assemblies to get the 'throw' of the slave piston into the proper range to operate the diaphragm 'fingers'. Too much play, or being at the extreme end of piston extension could leave the fingers just a bit from being depressed enough to release the clutch completely. It is just possible the 1st & 3rd synchronizer rings are a little less worn than 4th & 2nd. In my opinion, the 2nd gear synchro is the one that takes the most beating.
Finally, have you checked the level of lube in the transmission? If low, who knows what could be happening.
tom
With truck running and clutch engaged in neutral- If I depress the clutch I can go into
1st, 3rd, or 5th with no grinding whatsoever.
Under the same circumstances shifting into 2nd or 4th I get grinding. If I push clutch in, wait several seconds, and then shift into 2nd or 4th there is no grinding. Does this indicate a syncro problem?
My only reservation about saying it's the syncros is it shifted perfectly prior to the clutch going out. The only thing I can figure is I had to drive it to my house when the clutch went out and had to shift with no clutch (matching rpm's to speed)and maybe this did something? However, I could always match it perfectly and get it to just drop into gear.
If you use the wrong lube, there may not be enough viscosity to slow down the gears between shifts, or after the clutch is engaged and the lever moved.
I would check that I'm using the correct lube. If you have the right stuff, then I'd say your having movement of the gizzards {input shaft, counter gear} that when you apply forward pressure on the sliding ring & the synchro, the gears move forward and push the clutch disk against the flywheel, causing the gears to spin. This does not happen in 1 & 3 because the ring slides rearward to engage the gear. 5th is way back and doesn't do anything with the input shaft.
I do not have another explanation. tom
