Heat issues 03 Navigator
Old Feb 4, 2014 | 03:16 PM
Uwharrie's Avatar
Uwharrie
Just purchases a month ago. On the test drive it seemed the heat worked fine. Picked it up that evening ( dealership serviced it first) no heat! And the temp gauge never moved so we assumed bad thermostat. They replaced it, gauge moved but still no heat. System flushed twice, new TS installed, heat would sort of work ( warm air never hot) then blow cold. Dealership kept for a week could find nothing wrong and claimed it was fixed. It is blowing warm air but on high ( 90 with fan full blast) the car interior never really got warm ( 40 outside) our f150 will run you out of the vehicle after 10 min on high. Shouldn't the navigator do the same? Any suggestions?
Old Feb 4, 2014 | 05:39 PM
alloro's Avatar
alloro
The blend door is broken.
Old Feb 4, 2014 | 07:27 PM
Uwharrie's Avatar
Uwharrie
They supposedly checked that but will ask to be sure. Am I right that on high(90) it should be blowing HOT air?
Old Feb 5, 2014 | 03:38 AM
alloro's Avatar
alloro
Not just hot, but very hot.
Old Feb 5, 2014 | 05:58 PM
Uwharrie's Avatar
Uwharrie
The dealer is replacing the heater core.. They said the blend door is ok. Let's hope this is finally fixed
Old Feb 5, 2014 | 08:33 PM
pdqford's Avatar
pdqford
Is this the dual temp heater?
I believe the '03 used a vacuum controlled heater control valve in the inlet heater hose. Did you check to see that you had vacuum at the valve and the valve wasn't frozen in the "OFF" position?
Was the hose hot on both sides of the heater control valve?
Old Feb 6, 2014 | 08:56 PM
Uwharrie's Avatar
Uwharrie
It is a dual temp. Not sure if they checked vacuum but if replacing the core did not work I will ask them if they checked it
Old Feb 8, 2014 | 09:15 PM
Uwharrie's Avatar
Uwharrie
Well they replaced the heater core and now I have HEAT! Real HEAT! If they had just done that two weeks ago I would have been much happier! My SIL thinks the problem may have come from them mixing coolant types when the dealership serviced the vehicle post purchase.
Apocalypse
Jan 26, 2014 11:43 PM
tinman52
31
Jul 10, 2013 05:16 PM
terrapinME
6.4L Power Stroke Diesel
Jan 5, 2011 02:04 PM
cam_12484
2004 - 2008 F150
Dec 8, 2009 07:46 PM
amsrus
1997 - 2003 F150
Oct 30, 2006 08:42 PM
