E40D help
Old Feb 3, 2014 | 12:42 PM
nwertz555's Avatar
nwertz555
E40D help
I have a 96 Ford f super duty with a 7.5l and E40d after about 30minutes of driving O/D light will flash but still operate in all gears. Pulled codes and got
628 excessive converter clutch slippage and 657 fluid over heated. Now I have not felt a shudder which would indicate slippage like my 91 ford E40d does on lockup. And the temp never got above 210 until the light started flashing or I came to a stop. and front seal leaks also which in a tsb a read of another forum claimed that leaks can cause that code.
Any input would be helpful as I have already replaced solenoid pack after it got fried when the problem started last Monday
Old Feb 3, 2014 | 04:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Shudder doesn't usually happen when there is slippage. 99% of the time even an experienced person can't tell when it's slipping.
It is very common for the torque converter clutch apply piston to crack. This will lower the torque capacity of the converter clutch, which means it slips under load.
The fix is to replace the torque converter.
Old Feb 3, 2014 | 04:24 PM
nwertz555's Avatar
nwertz555
Ok which I probably shouldn't drive it until I replace converter so metal doesn't go everywhere.
And about the shudder like on my 91 ford f150 same trans just not as strong. almost everytime the converter locks up it shudders a little or when it unlocks it shuddees some. When it shudders is that more of the metal surface the clutch grabs is rough out rigid or something different altogether
Old Feb 3, 2014 | 04:36 PM
nwertz555's Avatar
nwertz555
And I'm assuming the converter slipping would quickly beat up transmission and cause it to overheat
Old Feb 3, 2014 | 07:53 PM
Mark Kovalsky
That is very unlikely to happen.
Something different altogether. It is caused by a change in the fluid and the friction surface. Sometimes shudder can be fixed by changing the fluid for fresh MERCON V.
No, not so much. It usually doesn't slip enough to generate a ton of heat.
Old Feb 3, 2014 | 08:41 PM
nwertz555's Avatar
nwertz555
Ok it did start after front seal blew out and left me stranded.
And also it overheating was my fault I had two external coolers in series and diffinitly restricts the fluid flow with 2.
Thanks for all your info I'll let you know how it's does one I replace seals and the converter
Old Mar 5, 2014 | 03:10 PM
nwertz555's Avatar
nwertz555
Ok got transmission back in everything is pretty good except 2nd has gone crazy, if you make a turn without coming to a stop there's no 2nd and it will go to first then 3rd and manual 2nd didn't do anything. Then if you stop and accelerate fRom a stop it's his 2nd like normal, shifter was misaligned at first and seemed to be the problem cause there was no 2nd at and converter locked up in reverse which it's fine now since I realigned shifter. Could a internal leak cause this or maybe solenoids are bad even though I just replaced them or should I look at the MLPS. Any input would be appreciated
Old Mar 5, 2014 | 03:40 PM
Mark Kovalsky
Low fluid, loose internal filter, or an internal leak can all cause this. A solenoid can't do all of this.
Old Mar 5, 2014 | 03:49 PM
nwertz555's Avatar
nwertz555
It's not low I no that for sure now should you once you put the filter in be able to wiggle any or should it be nice and tight
Old Mar 5, 2014 | 03:53 PM
nwertz555's Avatar
nwertz555
But that seems normal because there's nothing to support the filter it just hangs there unless you buy the strap for it
Old Mar 6, 2014 | 07:17 AM
Mark Kovalsky
It should be tight where it pushes into the trans. It does just hang there until the pan is installed, the pan keeps it in place.
Old Mar 6, 2014 | 07:32 AM
nwertz555's Avatar
nwertz555
Ok I'm gonna get another filter for it and I actually think the solenoid body is leaking it would make since it was just replaced
Old Mar 14, 2014 | 09:04 AM
nwertz555's Avatar
nwertz555
After replacing filter it seemed to get better but issue is still there and it doesn't happen until the trans gets to operating temperature which makes ne think it's a seal leaking or worn pump. Could a worn pump cause the trans to not downshift to second and only upshift to 2nd after a stop and converter clutch still drifts on reverse. I also had a theory that autozone filter necks were slightly skinnier then normal and maybe it's drawing air around the filter seal into the pump and I no there's tsb on the front pump should I look into that
Old Mar 14, 2014 | 09:27 AM
nwertz555's Avatar
nwertz555
And now man 2nd works again when I experience the 2nd gear issue before brother second gear would would unless I stopped or went to neutral then call to drive
Old Mar 14, 2014 | 01:54 PM
nwertz555's Avatar
nwertz555
Figured out trans problem it was in fact the tsb on the front pump now what exactly is the fix for that
