Sponsored by: Real Truck
problem starting truck
Old Feb 3, 2014 | 07:31 AM
redneck41's Avatar
redneck41
I have a 2008 f-350 6.4 diesel, I had to replace injectors and hi press fuel pump. Truck had to sit for awhile before i got to fix it now when I try to start it it cranks for about 2-3 seconds pauses and cranks foranother 2-3 seconds and stops. any ideas on what could cause this. thanks
Old Feb 3, 2014 | 08:37 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Sounds like you need to prime the fuel system. From what I remember you turn the key but do not start 6 times until the fuel pump cuts off, then try starting. Given that you replaced the HPFP and injectors I'd do it about 12 times to make sure.
I could be wrong, but that's the first thought that comes to mind.
Old Feb 3, 2014 | 08:44 AM
redneck41's Avatar
redneck41
thanks for info tryed that and still does same thing.
jasonhuber
1997 - 2003 F150
Oct 1, 2009 09:44 PM
elvia
18
Aug 19, 2007 08:49 PM
tlc auto
17
Dec 5, 2003 09:32 PM
ford5.8
Oct 18, 2003 04:21 PM
