1996 XL build thread
#31
#32
Well this is the clutch I will be going with the luk pro gold clutch
1995-97 4.9L 11" LUK Pro Gold clutch kit
Heard they are pretty good. Also replacing he rear main seal and seal at the transfer case and internal slave cylinder. Anyone upgrading to the 11 inch clutch before? If so did it make a huge difference
#33
#35
#36
Thanks. Probably going with that one. I was going to do it myself but I don't have the tools time or space. Found a shop that quoted me 600 if I bring the clutch set and they will replace the internal slave cylinder (ford). Rear main seal and the transmission to transfer case seal along with the shifter bushings with a 3 year warranty. That will probably my biggest project on it for a while.still need to buy spark plugs,wires,brake pads, and rotors. Waiting for a nice day to do the oil, coolant and seafoam. Then maybe the diff fluid. As far as cosmetics go I'm paint matching the grill and headlight bezels. Looking for new seats and a console(or just a bench seat console). Next year headlights tail lights and hopefully wheels. Looked into gears seems pretty straight forward. The parts list is the front and rear ring and pinion. And new differential carriers
#37
#38
#39
No Fords have posi. "Posi" (short for Positraction) is a GM trade name. Ford limited slips are called Trac Lock.
#40
Smoke smell: Have you cleaned all the windows yet? Had smoker's cars that I thought had tinted windows but were covered in smoke residue. Try CLR or make your own cleaner w/ 1 part vinegar and 3 parts water and use 000 steel wool, final clean w/ window cleaner & newspaper. Check the seals & gaskets around the windows, someone else could have cleaned windows well, but left sludge in gaskets & seals. Use CLR on all 'hard' surfaces, pull seat & floor covering & clean outside of truck, clean the floor while stuff is out. Pull ashtray assembly out of dash & check the underside of dash for leftovers from an overloaded ashtray.
How is the steering wheel & steering after new tires & alignment? If still out probably the TTB front axel needs a rebuild of bushings, pivots, etc. If you have your heart set on a regear of both axels start looking for used axels on CL or @ a local u-pull-it yard or a cheap parts truck, could do a SAS if you wish.
Wheels: paint them already!!!
Clutch: any adjustment in current set up (IDK)?
Coolant: Flush & add an external coolant filter.
Tune-up: Quality parts!
#41
#42
Well just ordered the clutch from bronco graveyard. The luk pro gold clutch since they don't have the standard luk clutch. Hopefully once it's up and running 100% I can start he cosmetic and mods. More then likely selling the toolbox to a friend and getting a chest toolbox to mount my fishing pole rack I'm building to. What's everyone's opinion on Roll on Bed liner. Vs the stock plastic insert. I pulled my stock out and only found a little bit of surface rust that I'm going to clean off and prime for now. Thinking about herculiner Roll on kit since spray on will cost an outrageous amount. Also was debating under coating myself or roll I. Bed liner in place of undercoating since their is only a bit of surface rust on the frame ends. To prevent any future rust. Still debating the head lights and tail lights since I dislike the ebay projector look but really would like a nice one piece light. As for tail lights might just polish up the factory's and pull them to seal them up since I have water in those as well
#44
#45
