Timing belt issues
Old Feb 2, 2014 | 07:02 PM
freednighthawk's Avatar
freednighthawk
Timing belt issues
Alright, it's been a while.
I've been at work all day helping to get my friend's 1996 Ranger 2.3 back on the road after the timing belt broke.
I followed all the directions I could find, both on line, and what came with the new belt/tensioner. Lined up the diamonds on the cam and oil pump, and lined up the crank at tdc before putting the belt on.
The issue is, it's not starting, and it's sucking in through the tailpipe, and blowing out the intake.
HELP!?! Please
Old Feb 2, 2014 | 07:17 PM
85e150's Avatar
85e150
Are you sure you are not 180 degrees out? If not, you have bent valves.
Old Feb 2, 2014 | 07:25 PM
freednighthawk
Pretty sure, there's only 1 diamond on the cam gear, correct?
Here's what I did: Turned the crank shaft untill the key was straight up, and the little tiny diamond lined up with the slot on the metal bracket, then set turned the cam untill its diamond lined up with the arrow at the 4:30ish position. Then set the oil pump to line up with it's mark at the 12:00 position, and then had to try 3 times to get the belt on there without anything moving.
Every 2nd crank rotation the marks all line up again.
Old Feb 2, 2014 | 08:26 PM
freednighthawk
Okay, I see on the cam gear both a diamond and an arrow. I lined it up on the diamond. I'm guessing I should have probably used the arrow instead?
Old Feb 2, 2014 | 08:58 PM
85e150's Avatar
85e150
If that is 180 degrees from the other mark, and nothing clinks when you turn the cam, you have your answer methinks....
Old Feb 3, 2014 | 07:26 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Triangle to triangle on the cam, diamond to diamond on the oil pump.
Both gears have the triangle and diamond. The diamond will be at the top of the cam gear when the triangles are lined up.
Old Feb 3, 2014 | 01:54 PM
tomw's Avatar
tomw
You won't bend the valves on a non-modified 2.3 Lima. If the followers have been changed, and the lift fiddled with, I guess you could have interference, but normally not on that engine.
nuts4hotwheels
Aerostar
Dec 5, 2011 04:44 PM
zman7125
Dec 9, 2008 08:31 PM
Dragonfox13
4 Cylinder Engines
Nov 25, 2008 07:55 AM
ranger55sh
Sep 13, 2004 04:42 PM
r4square
4 Cylinder Engines
Jul 26, 2004 04:32 PM
