Aerostar Ford Aerostar
timing issue
Old Dec 4, 2011 | 03:53 PM
nuts4hotwheels's Avatar
nuts4hotwheels
timing issue
I know that it isn't a ford but I need help from the Ford geniuses.
I have a 1997 Mercury villager. I replaced the timing belt. I align the three marks on the pulleys with marks on the belt. I turned the crankshaft by hand with a breaker bar and every two revolution the marks should align again, right? Well, every time it goes around twice, the belt is one notch advanced on the belt.
Old Dec 4, 2011 | 09:47 PM
96_4wdr's Avatar
96_4wdr
nissan quest
1993 - 1998 Nissan Quest | Nissan Quest Forum Community
Old Dec 5, 2011 | 04:44 PM
xlt4wd90's Avatar
xlt4wd90
I think it's more important to have the gears lined up to each other. The belt may or may not stay lined up with the gears, depending on how long it is, or how many cogs it has. So for example, if you have 14 teeth on the crank gear, you should have 28 teeth on the cam gear. But if the belt has, say 120 cogs on it, it will exactly line up with the gears once every 7 revolutions around the gears, during which time the crank gear should have turned 60 times, and the cam gear should have turned 30 times.
So the important thing is, if you turn the crank around twice, does the cam gear turn exactly once?
freednighthawk
1983 - 2012 Ranger & B-Series
Feb 3, 2014 01:54 PM
Gnnut
Sep 1, 2012 06:49 PM
Kijutsu
Apr 19, 2009 09:06 PM
zman7125
Dec 9, 2008 08:31 PM
okhunt
Apr 3, 2008 04:26 PM
