Sponsored by: Real Truck
Big tire blues
Old Feb 3, 2014 | 10:49 PM
DieselVol's Avatar
DieselVol
Originally Posted by dscabra
Where is the weight being stuck on during balancing? My local Discount Tire does Road Force balancing and the weight is put on along the inside edge of the spokes (nearly on the centerline of the wheel) with a couple of weights along the inner lip of the wheel. My tires are big and heavy and have none of the bounce you described. All my suspension components are pretty much new with the exception of ball joints (new springs, shocks, sway bar links, etc.). Another method that some of the off-road shops use on these bigger tires is the bead bags that they put inside the tire when mounting (can also be inserted through the valve stems). Once the vehicle is driven the bags break open and the beads dynamically balance the tires from that point on. I've never used them, and I've heard both good and bad from tire pros. You may also consider the possibility that you have a bad tire (manufacturing defect). Have you tried putting them on another vehicle to see how they ride?
Sorry, didn't see this response until now. I've had these wheels for over 4 years and 85k miles. I don't think anything changed about the truck itself such that putting them on another truck would tell me anything. I had balance beads in them when they were first installed, but they didn't help at all and I had them vacuumed out. I thrown a lot of money at this problem and so far, but haven't got much solved.
Old Feb 4, 2014 | 11:02 AM
Diamnd1's Avatar
Diamnd1
Click this link for info on RFB: http://www.tirerack.com/wheels/tech/...jsp?techid=109
Old Feb 4, 2014 | 03:26 PM
DieselVol's Avatar
DieselVol
Originally Posted by Diamnd1
That's the same unit Rickson uses. I spoke to them (Rickson) this morning and they assured me that 19.5 tires can be balanced this way quite well. I already knew that as my first set from them was very smooth. Hopefully the local folks can run their machine and get this fixed.
Old Feb 8, 2014 | 11:29 AM
DieselVol's Avatar
DieselVol
Well, got the road force balancing done already this morning. They had this exact machine from the link above. Three of the four balanced "within specs", but one would not balance. It seems it is a "bad tire". Now we begin the process of getting Toyo to replace it with a round one. As fate would have it, it was the left front tire. You can just imagine how much fun it's been to drive this thing with an unbalanceable tire right underneath you. If Toyo won't act right (yes, I'm troubling trouble...I have no reason to believe they won't do right), I can put it on the back and, if the vibration there is not noticeable, just not rotate the tires. My last set of 19.5 tires were different front to back and thus not rotatable. I only got 80k miles out of them and fronts could have gone more. I'll get the truck back shortly and see where we are now.
Old Feb 8, 2014 | 11:58 AM
WE3ZS's Avatar
WE3ZS
A while back I was looking at one of those Chevy C5500 Monroe pickup bed conversion fifth wheel hauler trucks. While doing my investigation on it I found several conversations online about owners fighting similar balance/shake/vibration issues with the 19.5's mounted on Alcoa rims. Seems that monroe was just mounting them up with a quick simple balance job and shipping them out. Several folks had the issue taken care of with the above mentioned RFB, others still had the same problems after the RFB. Eventually a decent heavy truck tire shop fixed one owner's rig by "trueing" the tire on the rim, I can't recall the proper name for the service but apparently this is somewhat common on "big rig" tires, basically high spots on the tread face. This "trueing" service actually shaves the high spots down till the tire runs as a true circle. The owner who had been fighting the balance/shake/vibration for quite some time was thrilled with how smooth the ride was following the "trueing" service.
If Toyo doesn't treat you right on this it may be worth contacting a heavy truck tire shop or two to inquire about the service......
Good luck.
Old Feb 8, 2014 | 12:07 PM
DieselVol's Avatar
DieselVol
Good luck.
Thanks, I'll keep that in mind. I don't expect a nice, smooth ride on 16 ply tires, but the "jiggle" will about drive you nuts. I can't imagine a several hours drive like this. I suspect you'd have that feeling we used to get from running a chainsaw all day before they started vibration isolating the handles. Make me feel nervous.
Old Feb 8, 2014 | 10:26 PM
DieselVol's Avatar
DieselVol
Good luck.
Got it back, just in time to get the stereo stolen out of it (see Stolen stereo thread) and it is MUCH better. There is still some bounce at about 45 mph, but the steering wheel no longer jerks around. I think the heavier shocks may still be necessary to calm down that dribbling feeling. I think I'll hold off on the shocks until I get that unbalanceable 4th tire (now on the rear) replaced to make sure that's not still a factor.
Old Feb 9, 2014 | 01:25 PM
caliaviation's Avatar
caliaviation
Now running 285/70/19.5 Toyo M608z tires, which are 35.5 inch, 16 ply tires. Yes, they are hard as plastic and yes, they are rough riders. They weigh 95 lbs each and the wheels add 67 more lbs. The problem I'm having, I'll call "dribble". At about 45 mph, the fronts will begin to bounce and that can continue for a while, but you can accelerate out of it. Usually around 70 mph or so, it will smooth out completely. The tires are well balanced, so that's not it. I'm wondering of heavier shocks could help by dampening the bounce. I put a Bilstein steering stabilizer on which may have helped some. I have new Monroe Reflexes now, but they seemed soft even before I got these tires. Any thoughts, other than, "those are big hard tires" I'm already aware of that.
Sounds like you've got it figured out with that one odd tire.
If this isn't the fix, I would suggest looking at your linkage, specifically the rod ends and the arm for excessive play. Even when you get everything sorted out, you may want to do this check fairly frequently, I'm thinking with those heavy suckers once you bump something the wrong way its going to throw a lot of things out of wack.
Old Feb 9, 2014 | 02:51 PM
DieselVol's Avatar
DieselVol
Yeah, I think you're right about that. FWIW, I don't recommend doing what I have done with these tires, but I have managed, so far, to cover all of my goals that sent me in this direction. If Toyo will send me one more round tire, the trade offs will be ok with me.
Old Feb 18, 2014 | 06:55 PM
DieselVol's Avatar
DieselVol
Good luck.
So it turns out that, in fact, "Toyo doesn't treat you right". They say that they consider road force balancing to have "too much variability" and will not warranty a product based on an abnormal RFB. I can understand why, since a few of my tires "balanced normally", yet about shook the body off of the truck until they were road force balanced. If all tires had to be round enough to stand up to RFB, Toyo would spend a lot of money replacing tires that failed RFB. Far better for them to just say "RFB is too variable" than to get me a tire that will roll right. Well I have 3 good tires, 1 bad tire, and a total of 4 of the last Toyo tires I'll ever own.
Old Feb 27, 2014 | 05:30 PM
Diamnd1's Avatar
Diamnd1
WOW! What a pain in the ****! Glad to hear you found the issue and know how to correct.
Old Feb 27, 2014 | 07:53 PM
DieselVol's Avatar
DieselVol
Well I agree on the pain part, but the only route to a fix is to hope that somehow or other the tire wears into "round". Not likely, but I can hope.
scottman70
Sep 7, 2010 10:41 AM
pedal2themedal
Offroad & 4x4
13
May 19, 2008 04:26 PM
nleditor
1983 - 2012 Ranger & B-Series
19
Nov 14, 2007 10:54 PM
hdf250
Aug 27, 2007 07:19 PM
my79f
Jul 19, 2007 05:44 PM
